It is currently Sat May 18, 2024 7:03 pm
Post new topic  Reply to topic  [ 513 posts ]  Go to page Previous 131 32 33 34 35
 Post subject: 7/18/23
PostPosted: Tue Jul 18, 2023 9:30 pm
After returning home from Carlisle. I got the car all cleaned and Checked on the valve lash. It seems that I either Have a lifter / pushrod not spinning or a Rocker arm that is not oiling out at the Adjuster screw. It's possible I might have to check on these rocker arms or just swap to stock rockers. We'll see.
I took the car to a local Car cruise tonight it was part of the Pittsburgh Vintage Grandprix "race week" where they have various events and shows all around the local area.
Here are some pictures from the event.
I took the hungry kid out for dinner, while the crowds were coming in and building up.
Then we walked back to the show where she was peddling her wares to the locals.
A few interesting notes.. since this is a local show near the town where I grew up, there were some Vehicles that My dad either had owned in his "personal collection" or sold at the car lot.
This 1933 Dodge Five Window Street Rod Sat around the house or garage since 1984 or so...
New owner is enjoying it and actually using it.
We parked next to a 1968 Dodge Dart GT that was sold off dad's car lot about 25 years ago. Same Owner has had it since he bought it off my dd in the late '90's
Tomorrow I will investigate the Rocker arm issue a bit more and swap to stock rockers if needed, or check for obstructions / drill an oil squirt hole on the chunky rockers if needed.
Oh yeah, remember this idea:
IT WORKS!
I have been taking the car hard around some Right Hand turns and no gas dribbling onto the quarter panel any more, so that is good. I just have to open the trunk and the valve when fueling up, but that is not a problem.
Planning on running the PVGP Countryside Tour Thursday.
PostPosted: Thu Jul 20, 2023 4:53 am
Cool pics and fun event.
Can you see which pushrod is not spinning? I hear the lifter/lobe will die quickly if no spin. Have fun on the tour today! Hope I can join next year...
 Post subject: 7/21/23
PostPosted: Fri Jul 21, 2023 8:06 am
@dart270: I did not verify that they are all spinning, but I assume they are or I would have lost a lobe by now. It was lack of oil from the rocker arms. It's fixed for now.
I participated in the PVGP Coutryside Tour yesterday.
It was ~120 Miles of Heavy Flogging on Wesmoreland, Fayette and Somerset County PA Back Roads and Mountain Routes.
I was a group leader, and the fantastic volunteer organisers of the event thought that the lowly '64 Dart Grüne Hölle Edition should lead off the fastest group first at 9:00 AM.
I had 4 Cars in my Group, all capable European Grand Tourers in their own right.
In my group:
2015 Porsche 991:
1995 Porsche Porsche 995:
1990 Porsche 964:
and a 1990 Mercedes-Benz 500SL
We had a blast ripping around some mountain roads and I made some new friends from Philadelphia and Delaware, it is usually unlikely that Porsche Guys were digging the Dart but they did. :D
This tour gets a way different crowd than the local car show car cruise guys which is refreshing.
It's safe to say that the engine is fully operating properly and spent much of the time between the 3500-5200 RPM range. Lots of Heel toeing and bliping of the the throttle for downshifts makes me smile, puts the engine in the proper RPM range to get torque coming out of any corner. 95 Mph Maximum Speed on routes that had no freeway or highway in sight.
2 days ago, I swapped what I call the "chunky" Roller Rockers out for stock Slant 6 Rockers.
I had Ran these "chunkies" for a few years with apparently no issues, but not now.
There is a lack of oil at the Rocker adjustment Screw. It was eating up Rocker screws because they were dry. That is why my lash needed reset a few times in the last 3 weeks. The solution there is to Install a Spray Bar in the Valve cover or Modify the Rockers for Adjuster screw oiling - Which is probably what I will do.
After I Left for the Trip, I realized that the Rocker arm Swap back to stock arms was causing some interference issues with the valve cover. (the vales on this head must be a bit taller than stock. I Had a bit of a diaper on the Valve cover during the Countryside tour to catch any oil that was getting ejected out of the car during driving, and for now until I can get some time to do proper cleaning, welding and metal work on this Valve cover I have the Side of the road / parts store hack..
On the #6 where the Valve cover is slimmed down for the Heater box clearance on '60-62 Models the Rockers were knocking and wore a hole through the metal.
This is also happening on the inside too as I can feel the Rockers clicking against the steel metal baffle inside above cylinders 5 and 1/ 2 where the PCV and Oil Fill is.
Quick fix for now:
' till next time.
