It is currently Tue Apr 23, 2019 7:08 am
Post new topic  Reply to topic  [ 84 posts ]  Go to page Previous 1 2 3 4 5 6
PostPosted: Thu Apr 11, 2019 7:16 am
Car Model*:
hoping this location works, haven`t ran it yet just cranked it over on the starter.
PostPosted: Thu Apr 11, 2019 9:20 am
Car Model*:
Rob how did you set tension on your belt? is it like my blower belt that has 1in of play at the middle long section too allow for shrinkage when the belt get`s hot?
PostPosted: Thu Apr 11, 2019 11:32 am
Car Model*:
Nice Setup there Terry, I might suggest to turn that filter adapter upside down to prevent messy filter changes - Otherwise it's great!
Greg Ondayko
69 Dart http://www.youtube.com/hyperpack
PostPosted: Thu Apr 11, 2019 11:39 am
Car Model*: Too many to list!! :-)
Hey Terry. I would not be the right person to ask. I've never had this thing running since I got it in 2011... :oops:
Hopefully this year... :roll:
Drag Racing
Commentator/
Points Keeper
PostPosted: Thu Apr 11, 2019 1:22 pm
Car Model*:
thanks Greg, was thinking of that but the used line and fitting I got on ebay limited me a bit but I have been changing oil with the filter up for all these years kind of makes me feel like I still have the stock pump!! :lol:
PostPosted: Fri Apr 12, 2019 5:21 pm
Car Model*:
changed the filter out line, gives me a little more clearance between the two lines.Image
PostPosted: Fri Apr 19, 2019 8:08 am
Car Model*:
reading rick`s post on -12 an line having internal spring, never checked mine to see if -16 an line had one. will these pumps suck the line closed and lose oil pressure?
PostPosted: Fri Apr 19, 2019 4:13 pm
Car Model*: 65 Valiant 2Dr Post
Not sure of the answer, but Greg had a line separate internally and close off as RPM went up. I put the spring in as a precaution. I'm guessing these pumps have a lot more suction than a normal pump.
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
PostPosted: Fri Apr 19, 2019 6:42 pm
Car Model*:
found 4ft length online have to order some. I see round stock and flat stock spring style, don`t know which is better for flow restriction??
