It is currently Sun May 31, 2020 9:20 am
Post new topic  Reply to topic  [ 112 posts ]  Go to page Previous 14 5 6 7 8 Next
PostPosted: Thu May 14, 2020 6:57 pm
Car Model*: 68 Valiant
Mine has a fitting drilled into the front of the block and an external pump from the lower tank of the radiator. Mike used a sprayer pump, but a pump for the rear heater in a Durango or minivan works just as well, and is about 1/4 the price.
https://www.ebay.com/itm/04-07-Dodge-Durango-Auxiliary-Water-Pump-Rear-Heat-55056340AA-OEM-Mopar-Heater-/381362428779
I think Dorman has this pump at Autozone or NAPA for about $100 less.
Then you can make your plate solid or drill the fitting into it like I did on my Daytona.
PostPosted: Fri May 15, 2020 3:09 am
Car Model*:
Looking Great!
PostPosted: Fri May 15, 2020 5:38 am
Car Model*:
Nice work, Stan!
Thanks for the water pump tip, Dennis...
"You mean you still have a Slant 6 in that thing?"
PostPosted: Fri May 15, 2020 8:06 am
Car Model*: More than I should have...
The Challenger is set up like Dennis’.
Drag Racing
Commentator/
Points Keeper
PostPosted: Sat May 16, 2020 3:54 pm
Car Model*: 1972 Dodge Colt
Now you guys have me thinking, and that hurts.
I will cut the plate and leave the pump cut-out off for now.
Dist fits, however I can't get the oil pump in or out, it hits the frame.
More thinking...
So here is the latest progress, man this part is fun!
Trans in place, block plate in the correct location, 30 degree tilt done.
PostPosted: Sat May 16, 2020 6:24 pm
So cool!
Drag Racing
Commentator/
Points Keeper
PostPosted: Sun May 17, 2020 6:01 pm
Figured out if I kick the front of the motor over a couple of inches, I could get the pump in. So I put all the stuff on the motor, put the front end back on with the hood and I have a 1/4 inch between the hood and the front breather. So I used the Offy valve cover and it has a pretty high standpipe. So if I cut a 1/4 inch off of that I will have plenty of clearance. First picture is everything installed and hood on, it fits! Now for the Headers....
PostPosted: Mon May 18, 2020 6:44 am
Car Model*: 1965 Plymouth Belvedere I
Will tilting the engine have much effect on the clutch and transmission linkage?
-Matt
http://www.MattmansMopars.com
Strive for Excellence, not Perfection.
PostPosted: Mon May 18, 2020 9:38 am
Badvert, the engine is at the 30 degree tilt as designed. The bellhousing is square with the frame, so all that stuff is right were it should be. The transmission rear mount is square to the rear crossmember. I am going to use a hydraulic throw-out bearing because I don't want to fabricate a bunch of linkage and rods in the close space I have.
Is that what you were asking?
PostPosted: Mon May 18, 2020 6:23 pm
Car Model*:
Getter done. .... Looking Good Stan!
Greg Ondayko
PostPosted: Tue May 19, 2020 10:11 am
Here's a picture of the headers Jeff Long built for my Daytona. You may end up doing something similar.
PostPosted: Tue May 19, 2020 4:36 pm
Nice
PostPosted: Sat May 30, 2020 7:19 pm
Mr. Burns sent me his last set of NA headers to see how they might fit.
The good news is except for a couple of spots they fit pretty well.
The bad news is they don't fit the Clifford Weber intake very well.
At least 4 tubes would have to be massaged quite a bit.
So thinking about getting the manifold from OZ and using that one.
It looks like the runners are a lot straighter.
Thoughts?
PostPosted: Sat May 30, 2020 7:47 pm
I still vote for building a set that fit like you want. Pay once, cry once, done. :mrgreen:
PostPosted: Sun May 31, 2020 4:29 am
Car Model*: 65 Valiant 2Dr Post
That is what I am running Stan. They do give you a little more room. They are 1.5" longer I think. Mine had to be massage quite a bit. Cross section was quite a bit smaller than the Clifford. Casting was off pretty good as well. Runners were not all level with each other when you laid a straight edge across them. Good news was there was plenty of meat to open them up and straighten them out. .
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
