Slant Six Forum https://slantsix.org/forum/ |
Rob's 1981 Dodge Challenger https://slantsix.org/forum/viewtopic.php?f=6&t=46322 |
Page 24 of 51 |
Author: | Rob Simmons [ Thu Jun 28, 2018 10:31 am ] |
Post subject: | Re: Rob's 1981 Dodge Challenger |
This here engine ain't fer winnin' rounds... It's fer goin' FAST! Maybe I'll git me 20 of them "record points" just fer good measure... |
Author: | Rob Simmons [ Sun Jul 15, 2018 4:10 pm ] |
I’m back from my class in Florida and not limping around too bad. I need to make sure the Duster is ready for Wilkesboro, but then I’ll start focusing on the Challenger. I need to swap the intake gasket to a thicker one to avoid some header/oil pan contact Howard noticed as we were loading it up. Then it’s just bolting things together (plus a couple hundred other things I’m sure. ) |
Author: | Rob Simmons [ Tue Jul 24, 2018 7:59 pm ] |
I pulled the intake/exhaust off the engine, dimpled one header tube to clear the oil pan and port matched my last Cox Brothers intake gasket to the Davis head. Now I can put it back together and get it back into the Challenger. |
Author: | Rob Simmons [ Fri Jul 27, 2018 6:47 pm ] |
I chased all of the threads on the intake/exhaust manifold studs. |
Author: | slantzilla [ Fri Jul 27, 2018 7:53 pm ] |
Did you catch them? Did they run fast? |
Author: | Rob Simmons [ Sat Jul 28, 2018 3:02 am ] |
They weren’t fast, but they were stubborn! I think Howard must have coated them with anti-seize or something. I’ll ask him. Yes, I caught them all. |
Author: | Ron Hamby [ Sun Jul 29, 2018 4:22 am ] |
Good idea. It sure helps with assembly to be able to run the nuts up by hand. Also I run the threads on the torque converter to get the old loc-tite out. It helps a lot too. |
Author: | Rob Simmons [ Wed Aug 01, 2018 7:28 pm ] |
I got the intake/exhaust remounted. I was getting things moved around to drop the engine in and said to myself, “Self. It might be nice to have them fenders off fer this.” Then Self said, “That’s a right fine idear. It’s only 4 bolts & a few rivets.” Good night Gracie! Forum won’t let me add photos. Pics to follow. |
Author: | emsvitil [ Wed Aug 01, 2018 7:59 pm ] |
Oh NO...…… you're answering yourself. |
Author: | Rob Simmons [ Thu Aug 02, 2018 5:17 am ] |
Pics or it didn’t happen. |
Author: | Rob Simmons [ Sun Aug 05, 2018 9:25 am ] |
Sprayed a little touch up paint on the chassis before the engine install. Heading to the lake now. No skiing for me. Torn ACL from my last adventure. Paint should be dry by the time I’m ready to wheel the engine over. |
Author: | slantzilla [ Sun Aug 05, 2018 1:38 pm ] |
Be safe bud! |
Author: | Rob Simmons [ Sun Aug 05, 2018 5:11 pm ] |
I took it easy today. No skiing and only one crazy bonsai solo jaunt on the jet ski. Not feeling like hitting the garage now though. Maybe just a little clean up... |
Author: | Rob Simmons [ Mon Aug 06, 2018 6:55 pm ] |
Ron Hamby wrote: Good idea. It sure helps with assembly to be able to run the nuts up by hand. Also I run the threads on the torque converter to get the old loc-tite out. It helps a lot too. I did that tonight. I cleaned up the ARP bolts and the holes in the crank and converter. There is one bolt hole in the converter I’m not real happy with, but not unhappy enough not to proceed. I only spent about an hour in the garage tonight. I thought about mounting the SFI flexplate tonight, but the wooden stand we made is in the way. I would have to spend too much time moving things around. Another night. I should look over the Duster before Knoxville this weekend... |
Page 24 of 51 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
