It is currently Wed Apr 24, 2024 2:29 pm
Post new topic  Reply to topic  [ 310 posts ]  Go to page Previous 111 12 13 14 1521 Next
PostPosted: Sun Nov 17, 2019 12:30 pm
My fan is a 3 1/2" thick at the motor and is 14" wide. Two 10's would be plenty also I'm sure.
PostPosted: Sat Jan 04, 2020 10:09 pm
One long boring Saturday...
https://youtu.be/z_M5gsmvxek
https://youtu.be/UN7Z9Mc5BXw
https://youtu.be/Kkf8ykZEUwA
https://youtu.be/w6DJmnCKnT4
https://youtu.be/3zuzuOQ9-rY
Dodge Polara R/T, to bad they didn't ship them up here.
PostPosted: Sun Jan 05, 2020 2:33 am
Online
Thanks for sharing. Inspiring stuff. Seymour's (my) white 62 Valiant would fit right in with those guys... Would need to uncork the exhaust, of course.
Home of Slant6-powered fun machines
PostPosted: Sun Jan 05, 2020 6:43 am
They really believe in long headers down there. Thanks for posting.
PostPosted: Sun Jan 05, 2020 6:27 pm
Yeah, they are not afraid to rev the beejeezes out of them either. There's a video of a early valiant turning 6 grand on a on ramp for the local freeway. There is another of a 225 with EFI along with a ITB intake with a claimed 380hp. I can't find that one again.
I guess it helps when you don't have a bunch of BB guys telling you are wasting your money on the \6.
PostPosted: Sun Jan 05, 2020 6:50 pm
Online
I've had mine over 7000 on a burnout. I used to shift it at 6700. Slant rods are alot tougher than they get credit for. :mrgreen:
PostPosted: Mon Jan 06, 2020 2:44 am
Online
Given the forces involved with the long stroke, it is amazing how much RPM the 225 can take, if properly set up.
My rev limits:
- 5600 on my 68 Dart (stock rebuild in 1989, nothing fancy)
- 6000 on my old 64 motor (stock rods and cast pistons, but balanced and loose clearances, saw 6200 occasionally)
- 6200 on cast crank motor for 64 Dart (saw 6800 in burnouts a few times, only one with forged pistons)
- 6200 on long rod (stock 198s) in Project V
Only one bearing failure in 30 yrs and that was due to oil starvation (check the oil before autocrossing, dude!). Project V saw 6600 once or twice at my last track outing when downshifting (oops).
PostPosted: Mon Jan 06, 2020 8:23 am
Online
My present motor is a cast crank, stock rod, cast piston deal. :D
PostPosted: Mon Jan 06, 2020 9:23 pm
You'all must be wrong, the fabo experts say there is no way a 225 can turn over 4800 rpm.
PostPosted: Mon Jan 06, 2020 10:25 pm
Online
I've seen the "experts" from that clown show.........
PostPosted: Wed Jan 15, 2020 7:54 pm
The skunk works, were all the magic happens.
Not much magic happening right now, in parts collecting mode.
PostPosted: Mon Apr 20, 2020 8:34 pm
Boxes are arriving from Summit. This one contains a gasket set and assembly lube. More to come...
PostPosted: Thu Apr 23, 2020 8:36 pm
.10 under rod bearings today.
PostPosted: Fri Apr 24, 2020 10:14 am
Build away and keep us posted! :D
PostPosted: Fri May 01, 2020 10:02 pm
So I bought a clutch kit. I carefully researched the available candiates and placed my order and I get a 10.5" clutch kit instead of the 10" one I thought I had bought. Now I need to return it at my cost plus a 15% restocking fee.
So what are my options?
I have a complete 11" setup. But the a833 doesn't bolt on and dusteridiot says it won't fit in my '65. I have a F-Body aluminum bell housing and clutch fork. But that has it's own problems. Mostly with the Z-bar and piviot points. And my good ole '64 setup that I have been using forever.
The current clutch setup is a SPEC 9.25 Stage 2. I didn't have the problems, that others experienced. Not sure why. I guess I was lucky? But it has worn to the point that I need to replace the disk and throwout bearing. I usually replace this stuff as a unit and I guess the SPEC clutch is still available.
So in the morning I guess I'll stop by the UPS Store and see how much it will cost to ship back and try again.
