Slant Six Forum https://slantsix.org/forum/ |
Mad Max Header pics https://slantsix.org/forum/viewtopic.php?f=6&t=58145 |
Author: | madmax/6 [ Wed Jul 29, 2015 2:49 pm ] |
Post subject: | Mad Max Header pics |
Headers for Max:) Snakes everyplace aaaaaaaahhhhhhh:) |
Author: | Dart270 [ Wed Jul 29, 2015 2:58 pm ] |
Post subject: | |
Gorgeous! Fenderwell headers for a Slant A-body - might be a first? BTW, Bonneville Speed Week is cancelled due to junky salt conditions. Might go for Sept 12-15 event if salt improves. Four words: Master cylinder heat shield. Slant on, Lou |
Author: | madmax/6 [ Wed Jul 29, 2015 3:02 pm ] |
Post subject: | |
Will do a heat shield and headers will bee ceramic coated inside and out. |
Author: | slantzilla [ Wed Jul 29, 2015 4:18 pm ] |
Post subject: | |
Very nice Mark! |
Author: | madmax/6 [ Wed Jul 29, 2015 5:41 pm ] |
Post subject: | |
Hardest most time consuming,over 200 hrs work, I have done on the whole car.Hope its good for a 10th.I am a better weld grinder than a welder.All primary tubes to the hand made collectors are within 1.5 inches ,34 to 35.5.Got close to a grand in material.Will only bee gratified if car goes quicker. |
Author: | Will [ Wed Jul 29, 2015 6:05 pm ] |
Post subject: | |
Good job. I know that takes a lot of work. Will |
Author: | madmax/6 [ Wed Jul 29, 2015 6:51 pm ] |
Post subject: | |
Will,you understand the stupid hours spent trying to go faster.If I won the lottery I would build a turbo motor and bee in the 9s.I dont buy tickets so that Will never happen.Your car has inspired alot of my goals and hard work and my retirement fund beeing depleated.I thank you,,,now. |
Author: | Pierre [ Wed Jul 29, 2015 7:15 pm ] |
Post subject: | |
Eeek! You'd spend a grand for a 10th?? Nice. |
Author: | sandy in BC [ Wed Jul 29, 2015 7:37 pm ] |
Post subject: | |
10 second car......100 tenths 10 second car ....$100,000 |
Author: | madmax/6 [ Wed Jul 29, 2015 7:38 pm ] |
Post subject: | |
NO,,,,,Hopefully a 10th and a couple hundred hours,yep,I aint all there.Then again I would like to lower my 10 records. |
Author: | Rick Covalt [ Wed Jul 29, 2015 11:03 pm ] |
Post subject: | |
Quote: Then again I would like to lower my 10 records.
Install a 5 speed and you should pick up a few 10ths! |
Author: | Slanteast [ Fri Jul 31, 2015 7:47 am ] |
Post subject: | |
Wow, even if they don't pick up any they look awesome...nice job. Way cool. The five speed suggestion sounds like a good one too! Good luck Derek |
Author: | ceej [ Fri Jul 31, 2015 11:00 pm ] |
Post subject: | |
As always, your nuttier than the mad hatter! Exquisite workmanship, which I've come to expect from anything you touch, and, like all other over the top endeavours you take on, I'd bet the farm it nets you measurable gains. Bravo on your progress bringing your Valiant back to life! :bow: CJ |
Author: | terrylittlejohn [ Fri Oct 07, 2016 3:05 pm ] |
Post subject: | |
nice but I can`t see the pictures of the headers? |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
