http://slantsix.org/forum/
62 Valiant Race Car is Back
http://slantsix.org/forum/viewtopic.php?f=6&t=62336
Page 1 of 9
Author:  ryandcovalt [ Sat May 12, 2018 9:16 pm ]
Post subject:  62 Valiant Race Car is Back
So, After way way way too long. Seymour's Valiant is finally ready to race again. There were a few minor issues and an internal scraping sound that had me worried for a while but everything was identified and corrected and it seems to be ready to race. Dad helped me get everything finished up the last couple of weeks. We got the engine broke in properly changed and spent some time fixing leaks and little things and all that's left now is to send it down the track.
I took it for the inaugural run through Dads neighborhood just to make sure everything was ok. Made a couple of full throttle launches and ran it through the gears and everything seems good to go. If you have never launched a race car with a trans brake in your neighborhood I........well I guess I don't recommend it, but it was a lot of fun today. (maybe a bit on the scary side) We got a few pictures after I cleaned off the 3 years of dust.
So a quick update on the engine.
It is the same block, crank, camshaft, webers and general setup seymour had. We just rebuilt it using:
weisco/K1 pistons & Rods compression ratio of 13.8:1 up from 11:1
New cylinder head that (on the flow bench anyway) out flows the old head significantly.
Running a new multi layer steel head gasket that if it hold up we will try to make more/sell (they also fit the aluminum blocks)
Other than the slightly bigger bore, higher flowing head and extra compression, everything else is the same.
Looking forward to seeing everyone at mason dixon next week and if all goes well I'm hoping to start tuning and making this even faster.
Author:  Team Green [ Sat May 12, 2018 9:41 pm ]
Post subject:  Re: 62 Valiant Race Car is Back
This is great!
Mark
Author:  Charrlie_S [ Sun May 13, 2018 3:15 am ]
Kool Beans. Good luck at M/D. Wish I could be there.
Author:  Rob Simmons [ Sun May 13, 2018 4:55 am ]
Awesome!!
It’s gonna be a great year of Slant 6 drag racing! :D
Author:  Greg Ondayko [ Sun May 13, 2018 4:58 am ]
Looking good!
Author:  Badvert65 [ Sun May 13, 2018 6:11 am ]
That's fantastic!
Way ahead of me.
What sort of times was it laying down before the refresh?
I see some trick things there (no headlights).
More pics please.
-Matt
Author:  Rick Covalt [ Sun May 13, 2018 7:07 am ]
It was a record holder in A Gas for a long time at 11.487 was the best record.
Author:  Rick Covalt [ Sun May 13, 2018 7:25 am ]
Here is the central figure in making it go faster. New cylinder head. Has 7MM valves and flows really well. :D :D
Author:  Rick Covalt [ Sun May 13, 2018 8:38 am ]
Webers don't hurt anything either! :D :D
Author:  Dart270 [ Sun May 13, 2018 1:26 pm ]
FANtastic! Congrats to both Ryan and Rick. I am so excited to see this rocket on the track in 6 days!
Thanks for the rundown and for the hard work to make it all happen.
Author:  ryandcovalt [ Sun May 13, 2018 4:51 pm ]
Thanks everyone,
I'm excited to get it down the track and i'm really looking forward to seeing everyone in a few days.
Matt, I will try to take some more pictures when i get a chance. Dad already posted some pictures of the engine but the other great part about this car is how much work seymour did to lighten the chassis. He really did an amazing job of getting weight off of this car and if it wasn't for that it probably wouldn't have set a record. I will try to take some pictures of the lightening work that was done when I get a chance.
Next project is to figure out why the car bounces so bad right off the starting line. I have some more reading to do on Cal-Tracs and shocks. Once this car makes a few passes and I make sure there are no major issues, the plan is to figure out the suspension. I'm assuming sitting for 3 years didn't miraculously fix the suspension issues from before.
Author:  Ron Hamby [ Sun May 13, 2018 5:38 pm ]
Great work Rick and Ryan. I cant wait to see how she runs. I'm sure going to miss being there. Please get some pics and vids of the race if possible. Good luck and great racing to everyone. I hope to join you guys at Motor Mile in June. :)
Ron
Author:  drgonzo [ Sun May 13, 2018 5:50 pm ]
Wicked, cool cars!
Brad
Author:  slantzilla [ Sun May 13, 2018 7:36 pm ]
Good air it will go 11teens.☺
Author:  Rick Covalt [ Tue Jun 19, 2018 9:42 am ]
First thing you need to do is check pinion angle, then get more rear compression so it quits crushing the tires. Then, you can start tuning. Too much pinion angle will tend to make the car violent.
Dizduster on Moparts put up some very good videos last fall about shock tuning. If you can get the wonderful Search function to work over there they are definitely a good watch.
What pinion angle do you need with a super light car with a transbrake? It also has Caltrac bars on it.
Page 1 of 9 All times are UTC-07:00
