It is currently Thu Aug 13, 2020 6:39 pm
Post new topic  Reply to topic  [ 147 posts ]  Go to page Previous 13 4 5 6 710 Next
PostPosted: Thu Nov 28, 2019 7:54 pm
Online
Car Model*: 1972 Dodge Colt
Thanks guys, looking forward to racing with you guys as well.
It's just easier to post pictures on FABO, so most of my comments and photos are over there.
But I will keep posting here as well.
I got the Wilwood spindles yesterday, I will find out how they are going to work tomorrow.
Happy Thanksgiving Slanters!
PostPosted: Fri Nov 29, 2019 2:34 am
Car Model*: 65 Valiant 2Dr Post
Is it under the Slant 6 section over there?
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
PostPosted: Fri Nov 29, 2019 8:18 am
Online
Since it's not an A Body, I placed the thread in the Mopar Racer Forum.
Here is a link to the thread.
https://www.forabodiesonly.com/mopar/th ... lt.442249/
PostPosted: Mon Dec 16, 2019 9:10 am
Online
Progress
I have been working on the front spindle issue for quite a while now.
Last week I sent all the ball joints and Mustang II spindles back to Speedway and Jegs.
I just could not make any of it work with my old parts.
At first when I spoke with Strange they said they had no parts for my old stuff.
After talking with one of their tech guys I did find a rotor I can use.
So I ordered them and it looks like I am in business.
They sell a rotor caliper for these rotors and I would need to build mounts to my spindles.
I can use my spindles and front end parts. I just need pads for these AIRHEART calipers.
The worn out rotors were the problem that started this whole process.
Here is the old rotor next to the new rotor.
PostPosted: Mon Dec 16, 2019 9:36 am
Car Model*: More than I should have...
Sweet!! That's awesome! I'm glad you got (are getting?) that figured out.
Drag Racing
Commentator/
Points Keeper
PostPosted: Sun Jan 05, 2020 4:17 pm
Online
Lots of stuff working, not much finished. I did get the hood mounted. Found front brake pads and O-rings for the calipers. Trying decide if I want to build an aluminum trans as my main gearbox. Liberty will do steel bushings front and rear so it will be like the race case. Either a 2.66 or 2.47 first gear set. 30 lbs lighter than a steel setup. I have an old DC aluminum tailshaft housing for either front case I run.
PostPosted: Thu Apr 16, 2020 5:38 pm
Online
Sorry for not keeping up on my postings.
I joined Facebook this week so I could post on some Pro Stock and Don Hardy groups.
I have gotten some good info from some folks so I guess it will be worth it.
This week I almost finished the mating of the Lakewood Bell Housing to the block.
I have gotten the Flywheel, thanks Will, surfaced and mounted for fit.
Using a McLeod disk and a DC Green cover PP.
I will be using a Hyd throw out bearing.
Just need to fit the starter and it will be done.
Here is the complete mock-up.
Next to roll all this under the frame rails and trim the mid-plate and start constructing the front motor mounts.
PostPosted: Fri Apr 17, 2020 4:53 am
Car Model*:
Looking good!
PostPosted: Fri Apr 17, 2020 5:05 am
Car Model*:
Nice!
Any idea what that car will weigh when its all setup?
Greg Ondayko
PostPosted: Fri Apr 17, 2020 6:47 am
Car Model*:
Very cool!
"You mean you still have a Slant 6 in that thing?"
PostPosted: Fri Apr 17, 2020 9:55 am
Online
Greg no idea on weight. I know they added weight when it was a Hemi 4 speed car to run Pro Stock in the late 70's.
I have found the weight plates on the rear valance.
The driver then was around 230 lbs, I am at 180 so there is 50 lbs!
I have aircraft scales at work but I can't get them out of the plant right now.
I know it put it on the jack stands like I would do my Cuda and the Colt was WAY different.
I lifted up on the front and the dang thing started to rotate.
So I had to rethink that set up.
I have read on the interweb about the 4 foot 2x4 and a bathroom scale.
But till I mount the engine and get it all together it's not much point.
Shooting for 2250 with driver.
Thanks Guys
PostPosted: Thu Apr 30, 2020 7:19 am
Online
Working on engine and bellhousing placement.
Took the front end off for the first time, that is sweet to work on stuff.
Mid plate is proving to be a challenge.
Found 92 pounds of lead under the fuel cell.
So there is a 10th, right?
Little bits at a time.
PostPosted: Thu Apr 30, 2020 9:40 am
Pure Awesomeness!!! :D
Drag Racing
Commentator/
Points Keeper
PostPosted: Thu Apr 30, 2020 11:04 am
Car Model*:
Super. 10th and a half...
PostPosted: Thu Apr 30, 2020 11:07 am
Car Model*:
Looking good!!!
Users browsing this forum: No registered users and 15 guests
