It is currently Sun Jul 22, 2018 8:42 pm
PostPosted: Thu Jun 07, 2018 11:01 am
Car Model*: 64 Plymouth Valiant
Would like to find a new style distributor hold down for my slant. The 2 piece job that has a hold down and ring.
Anyone want to get rid of one?
sb
PostPosted: Thu Jun 21, 2018 6:48 am
If you don't want to part with one, how about sending one for loan, so I can make a pattern?
sb
PostPosted: Thu Jun 21, 2018 8:04 am
Car Model*: Too many to list!! :-)
Is that the long, flat piece that has a hole for the distributor and a hole for the hold down bolt? When I get my parts back from Howard I will look for you. I may have one. Didn't realize it was two pieces...
Drag Racing
Commentator/
Points Keeper
PostPosted: Thu Jun 21, 2018 11:11 am
Here is a link to some pictures of the pieces.
https://www.forabodiesonly.com/mopar/th ... 1972130864
The hard part to come by or substitute is the tear drop shaped piece that bolts to the bottom of the distributor.
sb
PostPosted: Thu Jun 21, 2018 11:20 am
Car Model*: 1965 Plymouth Belvedere I
They aren't really that difficult to make. I cobbled up some aluminum pieces (using the originals as a template) with a grinder, hole saw, and a file. I don't have a better pic with me at the moment. I only have the one set of OE pieces (from a 1979 Volare) and I am reluctant to loan them out.
I agree that they make distributor adjustments much easier.
-Matt
http://www.MattmansMopars.com
Strive for Excellence, not Perfection.
PostPosted: Thu Jun 21, 2018 12:12 pm
Hmmm... Mine don't look like that... :? :|
Drag Racing
Commentator/
Points Keeper
PostPosted: Thu Jun 21, 2018 12:26 pm
Badvert65 wrote:
They aren't really that difficult to make (using the originals as a template).
I get that you don't want to loan the piece out..you think you can you make a fairly accurate tracing of the OE part on a piece of paper and mail it to me?
sb
PostPosted: Thu Jun 21, 2018 12:53 pm
You know, 'dusteridiot' might have some of those parts lying around. He is/was the /6 Distributor wisperer.
-Matt
-Matt
PostPosted: Thu Jun 21, 2018 5:17 pm
Car Model*:
No they aren't... it's the claw that the junkyard pitches when they prep the truck at pick a part... I have like 30 of the teardrop rings, and none of
the claws to spare...
If you want the ring, PM me your address and I will send one, you just need to make a donation to the board in response.
PostPosted: Thu Jun 21, 2018 5:19 pm
Online
Car Model*:
What is annoying is that the smallblock holddown claw looks virtually identical but it is just different enough to not work.
If somebody was willing to make up a mold and do a casting run, or do a CAD mockup and CNC run, I think I actually have a late style holddown I would lend to the effort (so long as I got it back). However, if it is simple enough to whittle out of a chunk of aluminium, I like shiny lightweight parts better.
PostPosted: Thu Jun 21, 2018 6:33 pm
I have a claw I could loan out, but if you wanted it to work on earlier blocks, it would need to be re-engineered a bit. I made a claw out of a modified big block distributor clamp. It was the closest thing I could find (ready made), but it still wasn't really a good fit. I ended up making something from a piece of aluminum angle. It doesn't look like a hard part to make, it is 'similar' to a lot of others but the slant six dimensions are just enough different that no others will directly work.
-Matt
PostPosted: Thu Jun 21, 2018 6:41 pm
3 Deuce Webber
Car Model*: 66 Valiant, 82 D150, 94 Ram 2500 TCD
If someone wants tracings, or a for-real part to copy, I have a set of the original parts. But I would for sure need them back, they are going in my build for the Valiant.
PostPosted: Fri Jun 22, 2018 6:24 am
This is the 'claw' from my 79 Volare. Not much to them, but the dimensions are unique to the slant block. I haven't found any ready made claws (for other engines) that will work in its place.
-Matt
PostPosted: Fri Jun 22, 2018 4:59 pm
I will happily loan out my pieces to any CNC guy who thinks he could make this out of aluminum.
Jus' Sayin'
-Matt
PostPosted: Fri Jun 22, 2018 6:42 pm
I can't find either one around here.
sb
