It is currently Fri May 03, 2024 2:16 pm
 Post subject: Rod Linkage BBS
PostPosted: Sun Apr 21, 2024 3:09 pm
Car Model: 1964 Dart 270
Need a BBS with rod linkage for parts. Condition doesn't matter so long as the fast idle linkage and cam are good. Might use the throttle lever and shaft as well. Previous owner lost the fast idle cam and linkage, and I've been unable to find one separately.
Thanks
Brandon
____________________________
https://www.flickr.com/photos/162600228@N03/
 Post subject: Re: Rod Linkage BBS
PostPosted: Sun Apr 21, 2024 4:16 pm
Hello, I think I have one of those. I will check and get back to you.
PostPosted: Mon Apr 22, 2024 7:57 pm
Hello brandon, I checked my carbs to sell.. I have a twisty rod carb, but it is not a BBS but instead a twisty rod 1920. Sorry about that.
PostPosted: Mon Apr 22, 2024 8:06 pm
No problem, thanks for checking anyways.
Brandon
PostPosted: Tue Apr 23, 2024 6:31 am
I can't recall ever seeing a twisty linkage BBS. They were used much less than the 1920. At least in the areas where I lived/worked.
66 Valiant Signet 225 nitrous
PostPosted: Tue Apr 23, 2024 7:21 am
They exist.
I have 2 of them,on a complete, running engine that I am not parting.
cron
