It is currently Thu Apr 18, 2024 12:45 am
 Post subject: QT Bellhousing
PostPosted: Tue Feb 27, 2024 9:22 pm
Car Model: 1964 Valiant 2dr post
I'm hoping to find a Quicktime bellhousing from someone who has maybe abandoned a project or changed direction. I'm building a 243" engine and doing the T5 swap. Not looking for a deal, I have the money to make you whole plus some. Haven't been on the board in ages...so just hoping.
Thanks
Gearhead
AKA Karl Boe
64 GTO...10.80's@122 on street radials
Destroked 455, Qjet, stock ign, 2400 stall
64 Valiant
Old 225, 4spd, 2.92-8.75, 2bbl, headers
dual 2.25"
 Post subject: Re: QT Bellhousing
PostPosted: Wed Feb 28, 2024 6:36 am
There are Slant to T5 adapter plates readily available from gill welding for use with the F body / D100 Truck Overdrive Slant 6 Bell housing.
Maybe you need SFI / Steel housing for safety reasons?
Good Luck!
PostPosted: Wed Feb 28, 2024 9:16 am
Nice Valiant.
Someone need to figure a way to modify the common as heck stock bell.
With todays smaller clutches it might be all that is needed.
PostPosted: Wed Feb 28, 2024 9:58 am
Gill Welding already has that plate for a stock 833OD or 833 bell!
Home of Slant6-powered fun machines
PostPosted: Wed Feb 28, 2024 10:32 am
The 10 " clutch / Truck Pressure plate will fit into the 3-speed bell.
The problem with using a T5 adapter with the 3-speed bell, which I believe Gill welding can make the adapter work on the 3-speed bell transmission bolt pattern, is that the IBR Hole is too small, so you will need to open up the inside of the IBR Ø on that bell housing to fit the T5.
I have never done this swap - T5 onto a 3-speed bell, but the last Adapter Plate that I Bought/ Won is set up for this accommodation.
PostPosted: Wed Feb 28, 2024 10:39 am
Were are all the old school hot rodders....
Seems like a good plot for CARS IV.
PostPosted: Wed Feb 28, 2024 11:48 am
Hi Guys,
I already have a custom built WC T5 with 2.95 1st and .73 OD and the Gill adapter kit. Also have a a cast iron and aluminum bell. Car was already converted to four speed by me in 1992, but the tranny finally gave up the ghost after 500k or so miles. Started to feel strange in the mountains during the last two of 15 trips from Portland to the SF Bay area while taking care of my Dad while he was dying. Fortunately, when it blew I was only a mile or so from home.
Problem is that every clutch part # listed in all the threads I've read are not available anymore. I figured I have a lot of work to do on my car, so I have some time and thought if I could find a QT Bell and run a V8 flywheel, as some of you have done, clutch problem solved forever. Also...safety.
My wife is a welder and fabricator, and I own a machine shop, so modifying for starter is no biggie.
Like I said, just hoping to find one before I finish the rest of the car.
Gearhead
64 Valiant
dual 2.25"
PostPosted: Wed Feb 28, 2024 1:24 pm
Just a FYI. I got a flywheel and clutch from Rick a couple of years ago. The flywheel is for a slant six 130 tooth ring gear. It takes a 11 inch clutch that is recessed into the flywheel. It seems like the original application was a D series truck with a slant and a NP 435 trans. I plan on mocking up this flywheel with a A-833OD trans and bellhousing, to see if this all will fit (I think it will). Found a supplier for the clutch assy. and they can supply the clutch with organic, Kevlar, or combination of disc linings.
66 Valiant Signet 225 nitrous
PostPosted: Wed Feb 28, 2024 3:31 pm
Charrlie, won't the larger flywheel / ring gear require a different non 122T starter position?
If so, how is that accomplished?
PostPosted: Thu Feb 29, 2024 4:31 am
Greg, you are correct. Not sure what I was thinking. I was actually working on a 360 for my truck, and wanted to install a BH/flywheel/starter to crank it over on the ground. I was trying different parts, and got this wacky idea. I'll look into to it further after I get my truck running.
PostPosted: Thu Feb 29, 2024 4:34 am
Okay, usually you are spot on Charrlie! So, I was unsure on this one..
It's okay to have a brain fart once every 40 years. :D
PostPosted: Thu Feb 29, 2024 5:14 pm
Greg , Charlie was just testing you young whipper snappers to see if you were awake. We old folks don't make mistakes! Now where did I park my car? :D :D
PostPosted: Thu Feb 29, 2024 5:25 pm
My son has a Clutchnet clutch and pressure plate on Ebay right now. Heavy duty Borg & BecK with 6 puck clutch disc. Was installed and ran for less than 100 miles.( I think it was in his truck) This does bolt up to the stock flywheel pattern. Pedal effort was stiff. But it may be something you may be interested in. $180. He probably gave over $400 for it.
PS. Clutchnet was bought up or closed up I think.
PostPosted: Thu Feb 29, 2024 6:19 pm
I realized what I was doing wrong. I don't have much experience with standard shift parts. And compared the 11 inch flywheel to the ring gear on an automatic. The bell on the automatic is larger than the standard shift slant six bell. That "dished" flywheel does not fit in a slant A-833 bell housing.
Now back to regular programing. Sorry for the hijack.
PostPosted: Thu Feb 29, 2024 7:35 pm
Check the blue lot.
It's there with the other Covalt Clan Machines.
:D
cron
