It is currently Mon Apr 06, 2020 8:42 am
PostPosted: Sun Feb 16, 2020 3:46 pm
Car Model*: 80 volare, 78 fury 2 dr, 85 D150
as title says. Needed for an 85 D150. Illinois, south of Chicago, area.
PostPosted: Wed Feb 19, 2020 6:15 am
Car Model*: More than I should have...
I have a Super Six stack with carb and air cleaner. I don't have the kickdown rod.
I also have exhaust manifolds if you'd rather go that route.
We aren't too far apart. We can probably work out a Slant 6 parts transport network request somehow... :wink:
Drag Racing
Commentator/
Points Keeper
PostPosted: Thu Feb 20, 2020 10:42 am
That sounds interesting, Rob.
I have 1 more junkyard near me to try, when I can get out there more than 15 minutes til they close.
My son also gas a /6 truck, and since I have been looking, "monkey see, monkey do" now HE wants a super six setup.
If we super six his truck I won't need any kickdown linkage, (his is a stick) and with mine IDK if regular kickdown linkage will work (regular in terms of most /6s with auto trans came with the 904) because mine has a 727 in it.
If I find 1 super six, I'll probably put it on his engine, and take his set up for mine at least to hear mine run and make sure it's a good foundation before I do much else with it. If I find 2, well then I'll worry about mine.
PostPosted: Fri Feb 21, 2020 5:05 pm
Car Model*:
I might have what you re looking for. It's a 2bl intake with the exhaust. I live just west of you in Peru IL. I'll try to upload photos of it (no carb or air filter).
PostPosted: Fri Feb 21, 2020 7:40 pm
pm's sent. I did find me an exh manifold (only) today, still interested in Super six setup....
what I got today, though, will get me going good enough to try to fire this thing up finally...… that's an improvement over what I had.
PostPosted: Fri Feb 21, 2020 7:41 pm
cool! I do get out by Starved rock and JCWhitney now and then.
