It is currently Wed Nov 13, 2019 8:13 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
 Post subject: Re: Slant Six Headers
PostPosted: Fri Nov 08, 2019 1:30 pm
Car Model*: 65 Valiant 2Dr Post
I put a gasket up against Ryan's and ground the inside of the flanges as much as I could to get them kind of rectangled...... :( :(
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
PostPosted: Fri Nov 08, 2019 3:54 pm
Car Model*:
I have an old set hanging in the rafters. It has rectangular ports, and does not have the nuts welded to the flanges.
66 Valiant Signet 225 nitrous
PostPosted: Tue Nov 12, 2019 4:42 pm
Car Model*:
I had an old (mid-'80's) DC set w/the rectangular ports, no nuts, ports were so misaligned I had to grind & weld & re-grind to make it use-able. The later MP "round ports" set were much better w/nuts, they didn't really overlap the corners on a stock exhaust port exit much at all, but opened up would be an issue if You didn't tailor the ports to the rounded pipes from the start.
