It is currently Mon Feb 18, 2019 2:55 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
 Post subject: Read This First!
PostPosted: Sat Jul 09, 2011 7:38 pm
Car Model*: 2018 Eichman Digger
Prior to entering any transaction, please note that the Moderators and Site Administrators do not sponsor listings, or vouch that such listings are legitimate. If you have a poor purchasing experience, you will need to address the issue with the seller, your financial institution or the method used for payment. Moderators are volunteers from within the community, and are not equipped to pursue such matters for you.
NOTE: The exception to the above is a "sticky" post. These usually indicate an item that is being made by one of our members for the benefit of the community and has been tested and vetted by several members.
If you are selling something that isn't for a Slant Six, you are required to include that information in the body of the post, not just the header. Failure to do so may result in a suspension of your membership privileges if a problem arises from your post.
Please use common sense when purchasing from these listings. We can't do that for you.
Should you have a problem, let us know about it, and we will track the user's activity. Scammers will be removed from our membership.
Thank you for taking the time to read this.
