Click here to help support the Slant Six Forum upgrade!
It is currently Wed Jun 19, 2019 6:38 pm
PostPosted: Tue Mar 26, 2019 4:27 pm
Car Model*: Valiant
Entire head has been inspected within spec and has all thread holes repaired or cleaned
Shot peened
3 angle valve job concentric within .0001”
All new valve guides
New .100” oversized Ford 300 intake valves
New exhaust valves
New hardened exhaust seats
Rotator retainers on exhaust valves
All spring height and spring pressure is within factory spec
Resurfaced bare minimum just to make surface flat less than .007”
.1950” stem height +\- .030” (closer to .1950”)
$500
Image Image Image Image
PostPosted: Thu Apr 04, 2019 4:25 pm
Car Model*: 1964 Dart 225/A833 3.55 9:1 CR .473 lift 500AVS
[quote="Seanshnizzy"]Entire head has been inspected within spec and has all thread holes repaired or cleaned
Shot peened
New exhaust valves
What's the chamber volume? And are those stock valve springs?
PostPosted: Sat Apr 06, 2019 12:46 am
Car Model*: '69 D100
There's a shop I wanted to send my head to on the west coast, it's called Mopar Engines West. I might consider buying this if you could deliver it to them to do some work, mostly decking it and porting, then they could ship it to me when they're done. I'd be out $250 in freight if I had to ship my head to them anyway. Would you consider doing that?
'69 D100, 225 SL6, A745→NP435
PostPosted: Thu Apr 11, 2019 3:26 am
Car Model*: Valiant
This head is from Sierra College Rocklin California. I was one of the last students to pass the program. Bob Lobdall and Alex Wong saw the head and were impressed. If anything you can disassemble and port but I think it’s good as it is stock with the ford valves and new exhaust valves / seats. Mopar Engines West is good if you want a Re-Man head. Pm or text and I’ll send you the specs.
-Sean 916-670-0583.
PostPosted: Thu Apr 11, 2019 4:04 am
Car Model*: Valiant
They are stock CCs -.007” just to make the surface flat ( probably .-005” or .-006”). The springs all tested OK within stock so no need to modify unless you’re boosting.
Springs are 49-57 lb @ 1 11/16”. 1.687”
Guides are new .565” knurled
Valve guide clearance is > .002”
Good for new gas
Seat Contact: Intake .050” - .060”
Seat Contact: Exhaust .070” - .080”
I would use this head if I wasn’t daily driving my ‘71 rn
PostPosted: Thu Apr 11, 2019 7:42 am
Car Model*:
This is a very good deal. I paid more than this back in the late 90s to have a shop build me a head with Ford 300 valves. If I didn't already have a couple freshly rebuilt heads in my garage I would be very interested in this one.
PostPosted: Thu Apr 11, 2019 10:51 am
Car Model*: Valiant
Yeah I don’t really want to sell it but I’m too busy with school and some Ford stuff so, somebody can get a good deal if they find this before I overhaul my Valiant. I’d prefer to deal locally.
PostPosted: Mon Apr 22, 2019 9:05 pm
Car Model*: 1963 Plymouth Valiant
I am interested. I have a '63 head from a 225 I could ship back to you if we can negotiate on the price.
PostPosted: Sun May 12, 2019 7:39 pm
Car Model*: 1981 D150
Hi, I am in need of a cylinder head for my 81 Dodge D150 slant 6. Let me know if this one is still up for sale.
Barry Brinson Tampa Florida bbtsassa@gmail.com 813 986 1613
PostPosted: Mon May 13, 2019 2:42 am
Car Model*:
bbtsassa, This head may not be a direct bolt on for your engine. If the head is 1980 or older, it will bolt on to your 1981 engine, but the valve cover is different, and some minor valve train changes may be required.
66 Valiant Signet 225 nitrous
