Click here to help support the Slant Six Forum upgrade!
It is currently Wed Jun 19, 2019 6:55 pm
PostPosted: Wed Apr 17, 2019 3:04 pm
Car Model*:
Two real nice new water pumps made in America in 1977. These pumps fit all Slant-6 engines except the 1960 LG (170) motors; see here for one of those pumps. Aluminum housing with the bearing weep hole splash guard, a feature that was introduced in 1964 to keep crud from plugging up the bearing weep hole—see below—and "cost-reduced" out of pretty much all aftermarket pumps some years ago. These have the original type of ø3.5" cast iron anti-cavitation impeller as found on all pre-'68 water pumps before Chrysler themselves went with a cheaper plain stamped steel impeller. Very minor (dusty) surface rust on the separator plate is of no consequence (the ring visible on the plate, around the impeller, is from the cardboard impeller-protector sleeve in the water pump box). Bearings turn smoothly and easily. Hella finer than today's shelf stock from China or Thailand. $49 each. Postage from Northern Michigan. Send me a PM.
PostPosted: Thu Apr 18, 2019 7:14 am
3 Deuce Webber
Car Model*:
PM sent.
PostPosted: Mon Apr 22, 2019 10:22 pm
Car Model*:
Sale pending.
PostPosted: Thu Apr 25, 2019 5:14 pm
Car Model*:
Sold.
