Click here to help support the Slant Six Forum upgrade!
It is currently Tue Jun 18, 2019 1:48 am
PostPosted: Wed Apr 17, 2019 3:04 pm
Car Model*:
Here's a relatively difficult water pump to find. It's for 1960 170 engines. The difference is that the impeller is 3.25" diameter instead of 3.5" diameter. For 1961 the LG (170) block castings were modified to accept the 3.5" impeller that started out on the 1960 225, but the 1960 LG (170) blocks won't accept the 3.5" impeller, so if you have a '60 Valiant, or a '60 170, this is the pump you need. Equally suitable for usage in other Slant-6 engines running high RPMs (racing, etc) where you want to minimize parasitic losses. Smaller impeller = less drag.
Made in America. Aluminum housing with the bearing weep hole splash guard, a feature that was introduced in 1964 to keep crud from plugging up the bearing weep hole—see below. $59. Postage from Northern Michigan. Send me a PM. (other water pumps here)
PostPosted: Tue Apr 30, 2019 4:42 pm
Car Model*: 1962 Dodge 770 Lancer Station Wagon
Dan sent you a message on this pump.
PostPosted: Wed May 01, 2019 6:42 am
Car Model*:
Howdy, Stan. Sorry for the slow response; this pump was already spoken for last week.
PostPosted: Fri May 03, 2019 7:00 pm
Car Model*:
Sold
