http://slantsix.org/forum/
1960 Metal-Case Ballast Resistor
http://slantsix.org/forum/viewtopic.php?f=8&t=63521
Author:  SlantSixDan [ Wed Apr 17, 2019 3:48 pm ]
Post subject:  1960 Metal-Case Ballast Resistor
Another seldom-seen item: a metal-housing ballast resistor as used on the 1960 cars. Also works correctly on later-year vehicles including points-type ignitions through '72 and electronic ignitions that take a single, 2-terminal ballast resistor (that's with the 4-pin ECU; the 5-pin ECU uses a double, 4-terminal ballast resistor). Brand new, dressed so fine and lookin' so pretty. $9. Postage from Western Washington. Send me a PM.
Author:  SlantSixDan [ Thu May 30, 2019 1:43 pm ]
Post subject:  Re: 1960 Metal-Case Ballast Resistor
Still available.
