It is currently Tue Jun 09, 2026 3:22 am
 Post subject: Axleshaft Interchange
PostPosted: Mon Sep 06, 2010 6:32 pm
Can the just the axleshafts be swapped between A-body Mopar 7 1/4" rear ends somewhat easily, or would it be easier to swap the entire rear axle?
I have a '67 Valiant with the SBP 7 1/4 and was looking at options of swapping to the larger bolt pattern on the rear.
I found a '74 Dart 7 1/4" rear somewhat locally with the big bolt pattern, but I'm not sure if they interchange.
Scott - waywardgarage.com
Why is the rum always gone? Image
PostPosted: Mon Sep 06, 2010 6:39 pm
To go from small bolt pattern to large you have to swap the whole axle assembly. The shafts do not interchange. We discussed this recently. http://slantsix.org/forum/viewtopic.php?p=287053
 Post subject: -
PostPosted: Mon Sep 06, 2010 6:51 pm
Josh is right,The Mopar performance book that says this can be done is wrong.
PostPosted: Mon Sep 06, 2010 9:12 pm
Thanks guys!! I'm glad I asked first!! :shock:
