It is currently Thu Apr 18, 2024 7:50 pm
Post new topic  Reply to topic  [ 68 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Mon Feb 23, 2015 5:23 pm
Hi Bigslantsixfan. Will you ship to Argentina? I need two sets .. or maybe three ..
Can you get me a quote on shipping? Regards Martin
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
 Post subject: springs
PostPosted: Sun Mar 01, 2015 7:08 pm
I've had several people ask me questions this week so I'll try to answer them:
1.My kit will not convert "lean burn" distributors to conventional types with mechanical advance. If your car has lean burn, you need a different distributor, carburetor, and the ignition system needs a major conversion.
2. My chart includes advance rates for one spring in case you want to keep the OEM long looped spring. In this case, the advance rate will follow the profile of the lighter spring, until the slack in long looped spring is used up.
 Post subject: Sign Me Up Again
PostPosted: Wed May 20, 2015 8:12 am
PayPal sent for another kit.
Thanks...Don
1965 Dart 110k, 225, Carter BBD Super Six, 2 1/4 single exh., sbp manual scarebird front disc, 7 1/4 rear 2.94 sure grip, 14 x 4.5 OEM wheels, 833 OD with hyd. throwout bearing, HEI, electric fan, ram air/heated air, Accusump. http://plymouthcarclub.com/
PostPosted: Sat Jun 20, 2015 12:59 pm
i would like to buy a kit.
Thanks.
PostPosted: Sun Jun 21, 2015 9:04 pm
Tried to send funds to your e-mail,but it asked name address?
 Post subject: .
PostPosted: Sun Jun 28, 2015 9:04 pm
Heads up folks, there seems to be a scammer with an e-mail and PP account similar to mine. My addy is ; bigslant6fan@yahoo.com Please note that it is the number "6" and NOT the word "six"
 Post subject: Distributor spring kit
PostPosted: Sat Aug 08, 2015 4:05 pm
paypal sent for distributor spring kit. will pm shipping addy. Thanks
Ken
PostPosted: Mon Aug 10, 2015 8:51 pm
Have sent $55 for two sets via Paypal. If need be, PM me or call the phone# in the paypal notes. Thanks & Regards...
Current: 67 Valiant Signet 2dr HT project car.
74 Dart Swinger 225 Auto
Used to have: 65 Valiant 200 4dr HT w goodies.
PostPosted: Thu Sep 08, 2016 5:21 am
PM sent
PostPosted: Sat Sep 10, 2016 10:58 am
Shipping in the continental US. is $4.75. Shipping outside the US will cost $9.50 (Ouch!) to most Countries by USPS. Additional shipping for multiple kits will be 50 cents in the 48 state US.
 Post subject: Re: distributor springs
PostPosted: Wed Nov 15, 2017 5:02 am
payment sent! thank you sir.
70 Plymouth Valiant 4dr
PostPosted: Mon Feb 05, 2018 9:34 am
Car Model: 1971 Dodge Dart Swinger
Hi BigSlant6Fan,
I had sent a payment for the Slant 6 distributor spring kit, (Jan 4th 2018) but since I forgot to add my address (my bad) you refunded me the payment on Jan 11th 2018.
I re-sent another payment with extra tip added that same day (of $35 total) with my home address this time, and added the info in the PayPal note area (like I was supposed to do the first time).
I am in no huge rush, I just wanted to make sure I didn't get overlooked or forgotten about. :)
Also thank you for all your help & knowledge you have shared on the forums.
- Tony
Once I thought I was wrong.... but I was mistaken. :)
Here is my Ride: https://www.71dart.com/
PostPosted: Wed Feb 21, 2018 7:58 pm
71dodgedart wrote:
Hi BigSlant6Fan,
- Tony
I received my distributor springs just wanted to say thanks!
PostPosted: Fri Mar 02, 2018 6:11 am
In the original ad it says these fit "most mopar distributors..." --- should fit our slant AND my 318 Cuda?
How hard is it to change out springs etc?
PostPosted: Fri Mar 02, 2018 7:02 pm
If they are uniform springs and not the large loop style on the EI distributors they will fit the standard G,A, and B engine distributors....
The complication occurs when you use a long loop spring from a V-8 distributor that had an L17 governor slot, and the new governor is L9 to 15... (so no spring tension on the heavy spring on the advance which will act like no spring at all)...
If I remember right these are non long looped springs and will work for your applications.
Article to tear down distributor to refurbish or change springs is HERE
