It is currently Sat Feb 23, 2019 4:50 am
Post new topic  Reply to topic  [ 120 posts ]  Go to page Previous 1 2 3 4 5 68 Next
PostPosted: Thu Sep 29, 2016 6:42 am
Car Model*:
Sounds good on all counts. I am very interested.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Sat Oct 01, 2016 11:07 am
3 Deuce Webber
Car Model*:
Does anyone know where I can get some good quality starter ring gears? I need to get one in hand to mock up the new flywheel.
On another note, does the slant prefer a certain weight of flywheel? Are the aluminum flywheels too light for comfortable street use? I am planning on shooting for about 26lbs for the new thicker flywheel because the CD009 is known to chatter with a light single mass flywheel but I think a solid aluminum one would only be about 15lbs. However, solid steel would be about 40lbs so I would have to start whittling away the steel version to hit my desired weight.
PostPosted: Sat Oct 01, 2016 1:17 pm
3 Deuce Webber
Car Model*:
Custom flywheel taking shape. The pressure plate pattern is the Ford 10". I don't have a Nissan PP in front of me to finalize the 9 hole bolt pattern, but should have one soon. I also need to re-read the Ford PP swap thread to see how much the shift fork had to be shimmed. The added thickness of this flywheel may allow that swap to work better as well at 1.725" thick. This one currently weighs 30lb without the ring gear so I need to keep removing material.
PostPosted: Sat Oct 01, 2016 1:32 pm
Car Model*:
Nice Work.
I prefer a lighter rather than heavy flywheel. Of course my build will be Street / auto X / Road Race only!
I wonder if you can get a starter ring gear from an old stock flywheel or sacrifice an old stock slant 6 904 converter?
Greg Ondayko
69 Dart http://www.youtube.com/hyperpack
PostPosted: Sat Oct 01, 2016 2:06 pm
Car Model*:
O.
Available from Rockauto
PIONEER FRG130T {#1941648} Info
Standard trans.; w/Heavy Duty; w/ 131 Tooth Gear (Only 12 Remaining)
PIONEER FRG122T {#2121196} Info
Standard trans.; exc. Hi-Perf. Engine; w/ 122 Tooth Gear (Only 11 Remaining)
66 Valiant Signet 225 nitrous
PostPosted: Mon Oct 03, 2016 4:20 am
Car Model*:
I have been running 11 lb alum flys in my 64 Dart for 12+ yrs. No problem here. Steel insert of course. The Slant cranks are heavy, so plenty of inertia there to smooth things out.
PostPosted: Sun Nov 27, 2016 9:41 pm
Car Model*:
Looooong summer, back, still up for it.............
PostPosted: Sun Nov 27, 2016 11:15 pm
3 Deuce Webber
Car Model*:
I'm still working on it. I have to double check the dowel pin locations on the transmission side and purchase a mini starter then I'll be able to finalize the adapter plate. That will allow me to get the final measurements for the flywheel thickness. I recently purchased a new machining center and sold one so my shop has been busy catching up on purchase orders from the down time.
Would you be willing to pay a deposit for a kit? I get significant price breaks on the materials if I can order in quantities greater than 2 pieces, but I wouldn't want to sit on the cost of say, five kits worth of materials. I realize I would need to give you guys an actual price and bill of materials before you can make an informed decision.
I am also putting it out there that my install will probably be fairly slow because of life right now. I would prefer to put miles on the conversion before giving it to the public, but if some of you are interested in assuming some of the liability that comes with the testing phase of development and can get yours installed sooner, I'm willing to get you your parts at the same time that I make mine.
I've never done any kind of group buy before, so I could use input on how it would work.
Thanks,
Casey
PostPosted: Mon Nov 28, 2016 6:24 am
Car Model*:
If you get us a reasonable quote, I would be up for sending a deposit to cover materials.
PostPosted: Tue Nov 29, 2016 6:28 pm
Car Model*:
Yep,X2
PostPosted: Tue Nov 29, 2016 9:45 pm
3 Deuce Webber
Car Model*:
Will do. I'm going to plan on 4 sets of parts right now. I think 5 people, including me, have expressed interest, but only Dart270 and Killer6 have expressed interest recently. That will give me one extra set if there is a late bloomer.
PostPosted: Wed Nov 30, 2016 7:35 am
Car Model*:
Depending on the cost, I would be interested as well. Being now retired, got to budget for my play time.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Wed Nov 30, 2016 10:27 am
Car Model*:
Thanks, casedawg. Your efforts are appreciated.
Best wishes,
PostPosted: Wed Nov 30, 2016 1:29 pm
Car Model*:
I am interested as well.
Greg Ondayko
PostPosted: Thu Dec 22, 2016 6:25 pm
Car Model*:
I'm very interested in this also, I'd be willing to invest to help and I know they will be in high demand once you get it dialed in. Hit me up on here or a PM if this is still a go!
Marty
