It is currently Wed Jan 23, 2019 10:24 am
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Wed Aug 09, 2017 12:47 pm
Car Model*: 65 Valiant 2Dr Post
Approximate cost?
$2800
I know someone who has one in his possession. It is yet to be seen if the unit ever makes it onto a running car. From what I have seen (Just a quick look) it looked really decent.
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
PostPosted: Sat Aug 12, 2017 12:26 pm
Car Model*:
Holy moly!
I was originally thinking NA then going to turbo a bit later, but now I may need to reconsider some NA static/compression ratios and consider a bolt-on supercharger.
Would this unit still work with A/C? I imagine the blower pulley would be going where the stock compressor would go... that may be my only limiting factor. Relocating the A/C compressor and alternator may be an option, though.
I've seen some interesting dyno videos of a supercharged Aussiespeed car, which made very little power (still substantially more than stock), but made over 400 lb/ft of torque at the wheels. It was likely a limitation of the head or the bottom-end build that kept the motor from spinning fast enough to make some significant top-end horsepower, but wondering if this is going to be a similar design.
Either way, I'll be watching! :)
1972 Plymouth Duster:
- 225ci
- Offy 4-Barrel Intake
- Weber 38/38 DGES
- Clifford headers
- Split 2.25" dual exhaust
- Pertronix digital ignition conversion
- Black-out custom digital gauges
- Front disc brake conversion
- Viper Blue
Last edited by Leaning Dusty on Thu Jun 07, 2018 12:41 pm, edited 1 time in total.
PostPosted: Sun Nov 19, 2017 9:46 am
Car Model*:
Any updates?
PostPosted: Thu Nov 30, 2017 6:25 am
Car Model*:
I'm interested in any updates too.
http://www.torqstorm.com/supercharger_kit_slant_6.html
1970 Barracuda 225 /6, 3spd on the floor, Blue/Blue
PostPosted: Thu Nov 30, 2017 7:22 am
Online
Car Model*:
Rick,
Maybe my Project V can be a test mule for that kit you have laid eyes on??? In any case, I am thinking this might be a nice upgrade for that motor/car...
"You mean you still have a Slant 6 in that thing?"
PostPosted: Thu Nov 30, 2017 10:44 am
Ryan has one that he is going to put on his Dart once the restoration is complete. Probably mid year 2018 I would guess. Ryan has not posted about his Dart, but I have put eyes on it a couple times. It should be a sweet ride. 72 swinger Drag / Road race car. Front coil over/rack & pinion steering, rear 4 link, mini tubbed, and all the body stiffening you can think of. Power train will be a fuel injected Slant 6, blower motor, backed up by a Passon 5 speed with new 4.56 rear gear and huge tires. Body work is nearly done and it should be ready for paint sometime soon I would guess.
PostPosted: Thu Nov 30, 2017 10:58 am
Online
Car Model*:
Wow, cool! I better hurry up and spruce up the turbo car. I have many of those things on my list for this winter... I am still thinking about the TorqStorm and looking into that for the V.
PostPosted: Sun Dec 03, 2017 8:18 pm
Car Model*: 68 Valiant
Lou, how much hp would 9 psi support?
PostPosted: Mon Dec 04, 2017 3:14 am
Online
Car Model*:
Hi Dennis,
Based my turbo car testing, I'd say somewhere around 275-350 RWHP with the right overall combo and buildup. I am not sure how cam and things like that will affect things differently, but my car has made around 275 RWHP on 9 psi. That is with an old shortblock (170k miles), 8.6:1 SCR, Jeffrey head, MP 244 cam, and pretty conservative (pump gas and street friendly) timing and mixture settings.
My wheels are turning as well...
PostPosted: Mon Dec 04, 2017 8:09 am
That might just be enough to put a 2700# Valiant into Super Pro without breaking anything.... :shock:
PostPosted: Sat Jul 28, 2018 1:48 pm
Car Model*:
Thinking of buying one of these and slapping it on a stock supersix, then drive it until she blows up. Would it work on a stock slant with 2bbl carb? and add what, like 40hp?
The holy $#!+ factor when popping the hood would be worth the $$$...
PostPosted: Sat Jul 28, 2018 3:45 pm
Car Model*:
I suppose you'd need a 4 bbl intake manifold and a blow-thru carb...
After conversion to Canadian $$$, it would be cheaper to convert to a V8 using a donor car. And a crate motor. Hmm...
PostPosted: Sat Jul 28, 2018 4:59 pm
Car Model*:
$2800 and no AC provision means I am not interested in one of these. A turbo lets you keep all stock accessories.
PostPosted: Mon Jul 30, 2018 12:12 am
Car Model*:
I hear ya, it's freaking hot this Summer. A supercharger is definitely on my wish list though, along with a million other things...
PostPosted: Tue Jul 31, 2018 2:56 am
Online
Car Model*:
AC is not for hot rods. John Milner would never had allowed it.
