Slant Six Forum,  Forum Index
Home Slant Six Forum,  Forum Index Log in Register FAQ Memberlist Search
Click here to make a donation to the Slant Six Forum!
oil pressure dropping at higher RPM's
Goto page Previous  1, 2
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Engine
Select message display options:             View previous topic :: View next topic
DadTruck
Post subject: (Wed Sep 13, 2017 5:54 pm) Reply with quote
finished the re-install today on the oil pump, started the motor, test drive,,, all things are good.
cleaned up the work bench and noticed that the filter that I had removed was not branded as a Wix 51515, but as a Napa Gold 1515.
I believe that due to the similarity in the part number and the closeness of the viseable exterior construction a NAPA 1515 and a Wix 51515 are the same filters.
The Napa Gold 1515 filter that I removed has a Made in USA tag on it.
https://www.flickr.com/photos/13718356@N02/albums/72157685918007401
I have no intention of starting a ruckus, but the important point here is that..
what saved me and my motor was that I had upgraded the instrumentation on the 83 D150 from idiot lights to a variable gauge for the oil pressure.
If I still had an low oil pressure light, I would have been towing along at 2800 RPM or more, up hill, and never got a warning that the engine oil pressure was at 20 psi and dropping.
As there will always be global shifts that effect what we buy and use, focus on what you can control or monitor. Pay attention and you may be alright.
I have the NAPA 1515 on workbench,, to minimize shipping $, I'll wait till I need to buy a few more things from Summitt or Amazon then get one of the filter cutters.
thanks
Back to top
View user's profile Send private message
'67 Dart 270
Post subject: filter cutters (Wed Sep 13, 2017 6:55 pm) Reply with quote
I know it's been said, but a pair of tin snips are fine for cutting open a filter. Just poke a hole in the metal near the base of the filter and insert your tin snips and work your way around until the filter is cut. This won't add any metal bits to the inside and you'll be able to see what's in the filter easily. Yes, the jagged edges are ugly, but what's important is seeing what's inside, on the paper, in the shell. If there are any metal bits or sludge, you'll see it. The clean cut on the filter is nice if you want to pay for it, but in the end you're going to throw that out (I mean dispose of properly) anyway.
brian
Back to top
Post subject: (Wed Sep 13, 2017 6:56 pm) Reply with quote
John, how about a call to NAPA and/or WIX, and see what they have to say?
66 Cuda 170 nitrous
66 Valiant Signet 225 nitrous
Back to top
slantzilla
Post subject: (Thu Sep 14, 2017 12:56 am) Reply with quote
John, I have a cutter at the Skunkworks if you want to use it. Very Happy
Proud supporter of Mike Jeffrey Racing Engines since 1999.
Back to top
View user's profile Send private message Send e-mail
Bare Metal Maz
Post subject: (Thu Sep 14, 2017 5:46 am) Reply with quote
I couldn't agree more with regard to the installation of a an oil pressure gauge. I had an oil pressure issue (different to yours) that also turned out to be an oil filter problem. I would not have noticed the problem if I had only had a warning light.
See thread from the forum http://www.slantsix.org/forum/viewtopic.php?t=56819&postdays=0&postorder=asc&start=0&sid=a805041fa4b26242f36b0c73dd5f7de8
After cutting up the filter in question it looked really ugly! Again, if it wasn't for the oil pressure gauge, who knows what damage I may have caused.
Love cruising in a bare metal Val!
Back to top
DadTruck
Post subject: (Thu Sep 14, 2017 6:47 am) Reply with quote
a good idea,,filled out a form at the Wix technical support web site, describing the occurrence and asking if they want the filter back for analysis. I'll post their response
thanks,,I am thinking I should be looking at the filters off the Barracuda,
so I'll get one.
Back to top
shadango
Post subject: (Thu Sep 14, 2017 9:41 am) Reply with quote
I bought the cutter off summit specifically to see if anything was in the filter when we had issues with our 80 Volare last year....(there was)....
I open all my filters now.....its an easy to use tool and is fast....less dangerous than tin snips and wrestling an oily filter.
Well worth having IMHO.Will be watching this topic....I have switched to all wix filters and hate to think of having to switch again...LOL
Back to top
DadTruck
Post subject: (Mon Sep 18, 2017 6:59 am) Reply with quote
Wix Filter support line responded that they will get my contact info to a local NAPA filter rep.
The NAPA filter rep picked up the filter today and will send it to a lab for analysis-review.
He said around the end of the month he will have a report to forward to me.
I'll post what they find.
The rep confirmed that the Wix and NAPA Gold filters mentioned here are the same filters.
Back to top
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Engine All times are GMT - 7 Hours
Page 2 of 2
You cannot vote in polls in this forum
Go To Slant Six Forum Home
Mopar Ring Member Site
Powered by phpBB © 2001, 2005 phpBB Group
Theme created by Vjacheslav Trushkin, modified by Chuck Rivers
