Slant Six Forum,  Forum Index
Home Slant Six Forum,  Forum Index Log in Register FAQ Memberlist Search
Click here to make a donation to the Slant Six Forum!
Brake Bleeder Wrench Sizes
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Suspension & Brakes
Select message display options:             View previous topic :: View next topic
slantvaliant
Post subject: Brake Bleeder Wrench Sizes (Mon Oct 02, 2017 8:27 am) Reply with quote
The bleeder on my right rear 9-by-skinny drum is not 1/4", like the one on the left. It's 7mm.
7mm?
7mm.
No. I didn't try 9/32".
Is this common? Are wheel cylinders still available with SAE-sized bleeders?
This really isn't much of a problem. I speak metric well enough and have SAE and metric tools. I just prefer that this car require only SAE tools for routine maintenance, and as much other maintenance as possible. It simplifies logistics.
Mostly, I just hate the extra up/down transitions situations like this require. It's hard on the body!
Background: The brakes have been a non-problem for quite a while. I vaguely recall replacing that wheel cylinder, probably when I upgraded the fronts to disks. Maybe once since then. I probably bled it then without really thinking about the size.
During the recent engine swap, I noticed that the aluminum master cylinder was leaking. Installation of a new master cylinder led to flushing/bleeding the brakes all around.
I gathered the tools I expected to use before getting down to business. I had 1/4", 5/16", and 3/8" wrenches with me. I even tried different 1/4" wrenches, to no avail. I didn't expect a metric size. I did expect the same size right and left.
Tools aside, everything went well during the process. The fluid flushed out only had a little color to it and wasn't milky. The pedal feels firm now. The car isn't running, so I haven't tried the brakes on the street yet.
BBS, CAI, HEI, LBP, AC, AM/FM/USB, EIEIO
Back to top
View user's profile Send private message
makapipi
Post subject: 7mm screw (Mon Oct 02, 2017 8:44 am) Reply with quote
mine had a 7mm screw too, i removed it and installed a 1/4 screw.
also i check the mount screw and line fitting threads for right size and depth.
Back to top
SpaceFrank
Post subject: (Mon Oct 02, 2017 1:46 pm) Reply with quote
Yeah, I've seen new replacement wheel cylinders and calipers for various SAE cars show up with metric bleeder screws. I've got no data to correlate to different manufacturer brands, unfortunately.
1964 Dodge Dart, 225/904
Escape Velocity Racing
Back to top
emsvitil
Post subject: (Mon Oct 02, 2017 4:58 pm) Reply with quote
Does it have metric threads?
What's even worse are screws that are SAE and metric.
Either metric head with SAE threads or vice-versa.
Back to top
View user's profile Send private message Visit poster's website
Greg Ondayko
Post subject: (Mon Oct 02, 2017 5:11 pm) Reply with quote
Many time the avail. Offshore replacements are like this.. if originals are not broken sheared, stuck or cloged, and the threads are the same i try to reuse them on the replacement cylinders.
My 2 cents.
Greg Ondayko
69 Dart www.youtube.com/hyperpack
Back to top
DusterIdiot
Post subject: Yep... (Mon Oct 02, 2017 5:28 pm) Reply with quote
The RockAuto Raybestos brand rear brake cylinders I got for the Aspen were like that... I had to grab the closest X/32" wrench and make it work...
Not good...
Back to top
emsvitil
Post subject: (Mon Oct 02, 2017 5:59 pm) Reply with quote
I always break them loose (and final tightening)with the tightest 6pt socket
I also wrap Teflon tape around the threads so they won't rust weld.
Back to top
slantvaliant
Post subject: (Mon Oct 02, 2017 7:14 pm) Reply with quote
I didn't remove the bleeder, just loosened it to bleed the line.
Mixed-standard systems can cause serious problems.
Back to top
rich006
Post subject: (Tue Oct 03, 2017 12:06 pm) Reply with quote
My new Dorman wheel cylinders also had 7mm hex heads on the bleeder screws. I wanted to reuse my OEM screws but the threads were a different size.
Back to top
Post new topic   Reply to topic    Slant Six Forum, Forum Index -> Suspension & Brakes All times are GMT - 7 Hours
You cannot vote in polls in this forum
Go To Slant Six Forum Home
Mopar Ring Member Site
Powered by phpBB © 2001, 2005 phpBB Group
Theme created by Vjacheslav Trushkin, modified by Chuck Rivers
