It is currently Thu Jan 23, 2020 1:18 am
Post new topic  Reply to topic  [ 54 posts ]  Go to page Previous 1 2 3 4
PostPosted: Mon Aug 06, 2018 3:57 pm
Car Model*:
Rick, bring it to Knoxville.
66 Valiant Signet 225 nitrous
PostPosted: Mon Aug 06, 2018 3:59 pm
Car Model*: 65 Valiant 2Dr Post
How about clay City? I'll swap you those lifter for that! :D :D Not coming to Knoxville.
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
PostPosted: Sat Jan 26, 2019 12:21 pm
Sorry I never posted the part numbers that we used to fix the truck up and get it running. Andrew has been driving it ever since we fixed it without issue.
Parts came from Summit.
Flywheel. 50-3409 $79.97 Will need one hole drilled for the slant crank.
Clutch/PP Kit MU1647-1 $133.97
I got a call from another member here that is out in Montana, and he has the same flywheel set up that we did! So there were at least 2 of them! His was an 85 W100 also.
PostPosted: Sat Jan 26, 2019 1:43 pm
Car Model*:
Is that the 11" clutch?
And was the pp 3 fingers or a diaphgram style?
Greg Ondayko
69 Dart http://www.youtube.com/hyperpack
PostPosted: Sat Jan 26, 2019 2:04 pm
No that was converting to a standard 10 1/2" flywheel. B&B pressure plate I think
PostPosted: Tue Feb 12, 2019 5:28 pm
Car Model*:
I just pulled the trans and clutch from my 84 w100 and it is the same as the one pictured. We thought that yours was not original but it must be.
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Wed Feb 13, 2019 3:10 am
Oh No!! They're everywhere! :D :D :D
PostPosted: Sat Apr 06, 2019 9:07 am
Car Model*: 1985 dodge w100
I had the same problem,and I found a post here by a fellow in Pennsylvania with the exact same problem.
Here's the solution (per Pennsylvania):
1. Since there are no aftermarket flywheels for the 225, you must use 130 tooth, 10 1/2" for the 318.
2. Five of the crank mount holes lie up perfectly; the sixth off by a bit and must be redrilled.
3. Use the old flywheel as a guide. Bolt the flywheels together using the crank mount holes.
4. I used a transfer punch and a center drill to avoid wander.
5. Bolted the flyweels together again to use the old hole as a DRILL guide.
6. I made a plug for the old hole, but it's not necessary.
7. There are two types of flywheels: . diaphragm type or B&B. Your choice.
Works great!
Sorry, I don'thave any numbers. I can't find my notes (big surprise!) Fly about &75, B&B Clutch $100.
PostPosted: Sun Apr 07, 2019 11:14 pm
Car Model*:
Works great!
That's what Rick Covalt did. I took a much more difficult path and converted mine to a 727 torqueflite. :shock: :shock: :o :o :D :D
1972 'Cuda 340 4sp
1985 D250 360 46RH
