It is currently Sat Jul 20, 2019 7:46 pm
PostPosted: Wed Apr 17, 2019 2:41 pm
Car Model*:
I have a brand-new BBD for sale -- a real Carter one, not the Chinese counterfeit garbage. It's a truck carb, which'll run better than a car carb (less-stringent truck emissions standards = they don't have strangulation jetting). Been in climate-controlled storage, so not a corroded mess.
The carb is configured for manual choke. It's a Carter 4128s, 1970 Dodge D/W pickups and A vans with 318). Has long, spring-staged choke lever and appropriate bracket to accept a manual choke control of your own supply (they are not hard to buy, even now), and stepless fast-idle cam so you can pull the choke without having to remember to hold down the accelerator while you pull. Works a whole lot better than cobbling up a manual choke control on a carb configured for an automatic choke. Also has throttle dashpot to avoid herky-jerky when slowing down in a vehicle with a manual transmission (doesn't hurt anything on an automatic). Has closed-throttle idle (calibrated holes in throttle plates). $318 for this carb:
Postage from Northern Michigan.
PostPosted: Tue Apr 23, 2019 6:46 pm
Car Model*:
PostPosted: Thu Apr 25, 2019 5:22 pm
Car Model*:
PostPosted: Sun Apr 28, 2019 4:59 pm
Car Model*:
PostPosted: Thu May 30, 2019 1:43 pm
Car Model*:
Still available.
PostPosted: Tue Jun 11, 2019 7:49 am
Car Model*:
As seems to be the norm, can we meet somewhere between your 318 & our 225 (that's in my wife's Townie).?
Silly question #9; this will fit on the factory two barrel intake right.?
Cheers from Colorado.
PostPosted: Wed Jun 19, 2019 12:04 pm
Car Model*:
Sale pending.
