It is currently Sun Jul 05, 2020 3:21 am
PostPosted: Tue May 28, 2019 9:30 am
Car Model*: dodge a100
65 a100 , my clutch is way to hard.
all new clutch set, flywheel and linkage.
i was told a i can put in a diaphram clutch but cant
find a 10" ..
anyone know what fits ?
or where i can longer clutch fork?
or any other ideas to make this clutch not kill my knee?
PostPosted: Wed May 29, 2019 7:26 am
Car Model*:
Check the link:
http://slantsix.org/forum/viewtopic.php?t=48219
that's waht you want and it has all of the the necessary mods to do it correctly detailed in the article.
Parts availability from McLeod is no longer available.
you could try a centerforce 10" Mazda / ford Disc / pp probably with similar results.
https://www.jegs.com/i/Centerforce/183/ ... 9/10002/-1
https://www.summitracing.com/parts/ctf- ... del/ranger
You just need to invest in a a flywheel that bolts that pp cover.... which McLeod might make for you - or you could have Wilcap make one as well.
Good Luck!
Greg Ondayko
