It is currently Thu May 28, 2020 5:18 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page 1 2 Next
 Post subject: Autopsy findings
PostPosted: Wed Feb 12, 2020 10:46 am
Car Model*: 1966 Dodge Dart
The 225 has developed rod knock on a dyno pull after making around 120 hp to the wheels on 5 psi of boost. So I've pulled the motor, and following Doctor Dodge's book, I've started a teardown. First find... this may be a sign I should be looking for another block to build instead of keeping the bragging rights that it's the original engine.
File comment: Looks like a crack under the casting numbers.
Matt Cramer
 Post subject: Re: Autopsy findings
PostPosted: Wed Feb 12, 2020 12:14 pm
Car Model*: 76 D100
Was this after a rebuild or did you turbo the original unrebuilt 1966 motor? 120 hp and 5 ounds of boost seems like a low threshold for a rod knock to develop on a rebuilt motor.
PostPosted: Wed Feb 12, 2020 12:28 pm
Turboed an unrebuilt motor with what I believe are 200,000 miles on it. The odometer's almost to 100,000 miles, and I have had several reasons to suspect it's been around at least once.
It also had a badly tuned blow through carb setup on it, with more boost, prior to the current turbo and EFI.
Matt Cramer
PostPosted: Wed Feb 12, 2020 1:20 pm
Car Model*: 76 D100
Ah. Lipstick on a pig, then. It was probably near death from age and the boost just blew it over the edge.
"1966 slant six, engine. A slant barely alive. Ladies and gentlemen, we can rebuild it. We have the technology. We have the capability to build the world's best turbo slant. This slant will be that slant. Better than it was before. Better, stronger, faster." 8)
PostPosted: Wed Feb 12, 2020 6:51 pm
Car Model*: 1972 Dodge Colt
Crack, bad.
But I doubt that is the real problem if it's knocking.
PostPosted: Thu Feb 13, 2020 5:17 am
hyper_pak wrote:
Crack, bad.
Yes, I'll have more pics the further apart I get the motor. Just trying to document everything I find that's gone wrong here. There are three such cracks that I've found on the driver side of the block, which tells me I ought to be looking for a new core.
Matt Cramer
PostPosted: Thu Feb 13, 2020 6:10 am
Car Model*:
MadScientistMatt wrote:
hyper_pak wrote:
Crack, bad.
Do you have a core? If not, I wouldn't be supprised if you could get one at the slant six racing Banquet, at the end of this month.
66 Valiant Signet 225 nitrous
PostPosted: Thu Feb 13, 2020 6:50 am
Car Model*:
Crack is probably not from the turbo if you only made 120 HP. That is one place they can crack, although I have never had it happen on one of my blocks.
Yes, one of us could bring a core block to the banquet in Pigeon Forge, TN on Feb 29 if you want to join us.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Thu Feb 13, 2020 7:34 am
Car Model*:
Looks to me, like it was caused by freezing.
Pigeon forge is only about 4 hrs from you.
PostPosted: Thu Feb 13, 2020 8:15 am
Car Model*: More than I should have...
I gave Gary Bruner a buildable core he wound up not using.
I could bring another one up from KY, but need some advanced notice. I've still got stuff strewn about... :oops:
Drag Racing
Commentator/
Points Keeper
PostPosted: Thu Feb 13, 2020 10:15 am
I'm definitely looking for a core. I appreciate the offers - I will need to check my schedule to see if I can make it to the event, and check my $1300 beater pickup to see if it can make it to Pigeon Forge. :)
The rod knock was very definitely the #6 rod bearing. My suspicion is that the pick-up was not letting enough oil through on the high RPM dyno pulls. The crankshaft looks like it could probably be turned undersized and saved. The rod, probably not.
Also, the cam lobes aren't looking in the best of shape.
Matt Cramer
PostPosted: Thu Feb 13, 2020 11:31 am
Yeah,... I’d say that con rod bearing is a bit hammered.... :shock:
Drag Racing
Commentator/
Points Keeper
PostPosted: Thu Feb 13, 2020 11:55 am
Car Model*:
yes from the photo that pick up screen was blocked, for the next motor you may want to look at the
oil pump porting mods that Doc has posted here, nothing terribly crazy, but every little bit helps,,,,
the motor that I ran several slant drag race events in was the OE 68 Barracuda slant motor, the pistons, rings, bearings,
pushrods, rockers,,, were all OE parts.
took the motor completely apart, tagged and bagged everything, pistons , rings sets, bearings,,,so I could get them all back in the original location.
had the block and head and oil pick up/oil pan hot tanked, removed the end plugs and cleaned out the rocker shaft, cleaned up the rocker arms,,
used a ball brush to put a cross hatch back in the piston bores, power ported the pistons (that involves drilling small holes from the piston crown
to the top ring groove to put pressure behind the top ring groove). Bottle brushed all the passages. Re built the engine with all the: OE pistons, rings, bearings, rods,
rod bolts and head bolts, push rods, valves,,,. I put in a new timing chain, new 318 valve springs, a ported hydraulic motor oil pump, new gaskets, re ground cam and lifters, slight cut to raise
compression.
The piston bores and rods and crank journals are all out of spec for size and shape,,.
I have maybe 50 or so 6000 RPM runs down the strip.
Never an engine issue.
You can run an older motor hard, but if you want it to last, clean it out.
PostPosted: Sat Feb 15, 2020 6:25 am
Car Model*:
Autopsy?
Looks more like 8x10 glossy crime scene photos.
Should be rated "R". :shock:
PostPosted: Sat Feb 15, 2020 3:05 pm
Car Model*: 68 Valiant
I have a 225 I'll give you. Houston is very close to Georgia, so just drive over and I'll even load it for free and give you some cashews.
