It is currently Mon May 25, 2020 5:41 pm
 Post subject: Deleting a Post
PostPosted: Sun Aug 01, 2004 6:53 pm
Car Model*:
How do you delete a post?
PostPosted: Tue Aug 17, 2004 9:40 am
Car Model*: Many Darts and a Dacuda
You can only delete / edit a post under your user name, and only if there are no replies to it.
You must be logged in.
Use the little box icon with an "X" in it. It should be a small button on the bottom right of the post.
Another way is to edit a post to take out the text and then change the subject line to "Delete" and at that point a moderator will come along and clear out the post.
