It is currently Fri Jan 31, 2025 2:37 am
PostPosted: Thu Jul 19, 2007 1:29 pm
The 65 Dart Service Manual indicates "Camshaft Thrust Taken by Engine Block" and provides no end play spec for the 225 slant.
The same manual does provide end play for the V8's at .010.
When I rotate my 225 distributor rotor by hand (with the head off)I can see the cam moving almost 20 times the V8 end play(3/16).
Is this large cam end play a problem for my 65:?:
1965 Dart 110k, 225, Carter BBD Super Six, 2 1/4 single exh., sbp manual scarebird front disc, 7 1/4 rear 2.94 sure grip, 14 x 4.5 OEM wheels, 833 OD with hyd. throwout bearing, HEI, electric fan, ram air/heated air, Accusump. http://plymouthcarclub.com/
 Post subject: It can be...
PostPosted: Thu Jul 19, 2007 9:00 pm
I actually lost the bushing out of my timing gear (luckily 1 block from home) because the cam 'walked'. Doc has a quick post on how to make a cam stop to keep it in place. Use the search function and look for 'cam stop' by Doc*
I now do this to any slant I'm building.
PostPosted: Thu Jul 19, 2007 9:12 pm
A SL6 flat tappit cam has a taper on all the lobes which forces the cam rearward. The distributor / oil pump drive gear also pulls the cam rearward so in theory, the top (cam) timing gear will always be pulled up against the block surface.
I have see evidance that says otherwise... like a big rub mark on the inside of the timing chain cover. :shock:
To be sure the cam stays where it should, I weld in a stop made from a rockerarm adjustment ball screw.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 4 guests
