It is currently Tue Jun 09, 2026 9:19 am
 Post subject: 8 1/4 limited slip
PostPosted: Thu Jul 29, 2010 8:01 am
need the tourque spec for ring gear,pinion and carrier housing
thanks
 Post subject: Per 1976 Manual
PostPosted: Thu Jul 29, 2010 5:56 pm
Ring gear to diff case bolts -55 ft. lbs
Drive Pinion Flange Nut - 210 ft.lbs. minimum
Differential Bearing Cap Bolts - 100 ft. lbs
PostPosted: Fri Jul 30, 2010 5:38 am
thank you
PostPosted: Mon Aug 16, 2010 9:46 pm
thanks to all you guys...got the 4.10 limited slip in ....sure did wake up the 81 d150...also gain 5 mpg went from 10 to 15 yea , now on to engine
keep on roddin'
Users browsing this forum: Ahrefs [Bot] and 6 guests
