It is currently Mon Sep 28, 2026 9:27 pm
PostPosted: Tue Apr 02, 2013 9:46 pm
(ADDED ALL FROM ORIGINAL FAQ)
This is meant to combine most of the collective intel that we have here. Search the appropriate links for answers to your questions, if in the event you dont find it, try the "search" tab at top. Read what comes up, try diff search words, and then if its not found, make a post.
If there is something that is missing or you feel should be added, changed, deleted, etc. drop me a line or the admins and we will try to correct the situation.
HOW TO's
HOW TO:Simple GM HEI boost retard
TURBO THREADS/BUILDS
66 Valiant Drag Project "Charlie's Angel" (Kris)
Anatomy of a Slant 6 Drag Car-More updates!
Turbo Choice
Document your Turbo builds!
While Ive been off the Forum
Turbo Valiant Update
Turbo 74 Duster
68 Dart initiated into Boost Land
Turbo Toad
Dont Know if Turbo is going to fit...Help
Any articles on turbo carb'd engines?
Turbo your Slant Six by Wayne
TURBO CAMS:
Turbo Cam?
Turbo Cam
Looking for a cam for the Turbo Motor..
Lobsters Build
Cam selection for /6 motor
TURBOS AND CARBS:
Turbo with a 1bbl carb?
Whats better 350 or 500 cfm 2bbl?
Blow through Turbo
Blow Through Carter BBD?
Turbo engine Fail
Performance 1BBL carbs?
Making a 1920 Blow through?
New Turbo slant 6 owner
Vacuum Line question
Weird carb tuning issue...
Turbo setup in an 83 D150 with a 225
TURBO AND EFI
Blow through or efi?
Need resources: MPFI + Turbo
Megasquirt?
Throttle body options
Reeds Ford based MAF efi
TURBO HEADERS:
Turbo header started
Turbo header build
J Pipes
PowerPipe-DC (True Flow Header Design)
TURBO DYNO NUMBERS:
HP with turbo?
Turbo Dyno numbers
SUPERCHARGERS TOO!
Supercharged slant six
supercharger comp ratio
Centrifugaly supercharged Duster
RANDOM TURBO THREADS (parts, turbos,pumps, etc):
Articles
Slant Boom
Valve Size
Best block for Boost?
Twin Turbo question
Ideas's on turbo motor setup?
Build for a Turbo
Stall Vs. Boost
Turbo for TQ and MPG increase in a Truck
Turbo info needed
Fuel Pressure Regulator for Boost
What about these Turbos?
New racer being built
Water cooled bearing housing hook up?
Meth injection with or without intercooler?
Intercooler Flow
Boost Vs. N2O Squabble
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
PostPosted: Wed Apr 03, 2013 5:20 pm
Site Admin
Now all we need is titles to slap on the various links! :D
CJ
PostPosted: Wed Apr 03, 2013 6:30 pm
CJ
X2 nice job
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Wed Apr 03, 2013 6:48 pm
Site Admin
Don't cut an paste, just continue on here.
All the items have been added into the FAQ. If you have the time, put a little blurb next to each link, and I'll make the link read what it's about rather than a random string of gibberish! :lol:
CJ
PostPosted: Thu Apr 04, 2013 8:14 am
How's that Ceej? When I get to work tomorrow I'll add more of the lengthy topics I seen on the other pages, as I know there are more.
PostPosted: Thu Apr 04, 2013 8:41 am
Thankies for the linkies!
PostPosted: Sat Dec 20, 2014 6:44 am
Added how to section and gm boost retard
