Click here to help support the Slant Six Forum upgrade!
It is currently Wed Jan 29, 2020 12:35 am
 Post subject: Re: my turbo valiant
PostPosted: Mon Jan 08, 2018 9:13 pm
Car Model*:
MJF wrote:
Looking good! Do you have picture how you mounted LS coils? Or trigger wheel?
there are pics just above how the LS coils were done, i'll go for a dig and upload a few pics of both the trigger wheel and earlier stages of coil mount now for you though
PostPosted: Mon Jan 08, 2018 10:04 pm
Car Model*:
i only did the mount like this for the coils due to having 2nd handies that someone cut one of the mounts off to do some kind of coil straight on plug setup, i'd have made the bracket to use both mounts if i had non modified coils
basically the only pics i do not have of the trigger wheel are where i skimmed the inside of the rear of the balancer for a flat mating surface for that adapter hub/ring that i made, and it bolts through the front of the balancer.
PostPosted: Tue Jan 09, 2018 1:21 pm
Car Model*: 1965 Valiant 170/A833/8 3/4SG
Thanks for pics, looks beefy enough 8)
PostPosted: Wed Jan 10, 2018 12:16 am
Car Model*:
no problem, way overkill, just material i had laying around
