Slant Six Forum,  Forum Index
Home Slant Six Forum,  Forum Index Log in Register FAQ Memberlist Search
This forum is now closed.
All data from 8/29/17 to 11/14/17 was lost (Sorry!).
The new forum is here.
'73 Dart Slant Six Fuel Gauge
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    Slant Six Forum, Forum Index -> Parts Wanted
Select message display options:             View previous topic :: View next topic
GreybeardGunner
Post subject: '73 Dart Slant Six Fuel Gauge (Mon Aug 14, 2017 2:26 pm) Reply with quote
Hey Everyone:
Trying to track down an erratic gauge problem. I have the correct tank and the correct sending unit, but the fuel gauge reads full for about ten miles, then drops quickly to empty. However, there's still lots of fuel in the tank!! I am looking for a good used fuel gauge to swap out with the one currently in the car. I am hoping this will solve the issue. If you have spare, please let me know.
1973 Dodge Dart 225 Slant Six
Cheers,
Shawn
Back to top
View user's profile Send private message
earlyvalerie
Post subject: (Sat Aug 19, 2017 9:43 am) Reply with quote
It can be very easy to puncture the brass float when transferring it from an old sending unit to a new one. So if you've changed out your sender float I'd recheck that. To test your gauge remove the sender wire from the tank sender and put it to ground. turn key on - dash gauge should immediately go to full and stay. If it does dash gauge is good. If it doesn't either gauge is bad or wire to gauge is bad. I have a good gauge if needed.
Back to top
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    Slant Six Forum, Forum Index -> Parts Wanted All times are GMT - 7 Hours
Page 1 of 1
You cannot vote in polls in this forum
Go To Slant Six Forum Home
Mopar Ring Member Site
Powered by phpBB © 2001, 2005 phpBB Group
Theme created by Vjacheslav Trushkin, modified by Chuck Rivers
