It is currently Wed Jan 23, 2019 10:29 am
PostPosted: Sun Apr 15, 2018 1:17 pm
Car Model*: 1964 Plymouth Valiant convertible
Just purchased my '64 Valiant a couple months ago. Want to align the quarter trim. Appears that to gain access to the length of trim - working from front to back - remove fender, interior kick panel, arm rest, door handles, interior door panel, rear seat, rear arm rest, window handle, rear panel. I've seen specialty tools for "popping" interior panels - some consist of one tool or several. Anything I'm missing, should be aware of before proceeding, and/or necessary tool/s?
TONY
PostPosted: Sun Apr 15, 2018 2:12 pm
Car Model*: 65 Valiant 2Dr Post
Probably a good idea to check your door hinge bushings and get everything correct on the door before you start aligning trim pieces.
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
PostPosted: Sun Apr 15, 2018 6:25 pm
Car Model*: 1962 Dodge 770 Lancer Station Wagon
Some of the trim snaps in using the factory clips. Be very carful removing them, trim clips are impossible to find.
On my wagon the chrome roof trim bolted in under the headliner.
Good luck with your project.
PostPosted: Mon Apr 16, 2018 4:28 pm
Yep- the doors gaps look good and match body creases well.
