It is currently Wed Jan 23, 2019 2:28 am
PostPosted: Thu May 17, 2018 11:36 am
Car Model*:
My current Dash Pad is all cracked up. Is it possible to replace the dash pad? Does someone repop the pad? Help me out.
66 dodge dart 270, 225ci, 3.7l, L6
PostPosted: Thu May 17, 2018 11:45 am
Car Model*:
Yes, if it's like the typical chrysler dash pad, then at the upper rim of the sheetmetal body of the dashboard will be a series of about 5 even spaced studs with
a stamped sheet metal trim lock nut (I think on the late cars it's a 7/16" socket to get them...and a couple wobblies if you leave the heater controls and instrument
cluster in place...
Unsure about who supports the pre-67 vehicles, but typically they carry a vinyl/plastic 'cap' that goes over the cracked pad in lieu of full replacement.
PostPosted: Sat May 19, 2018 7:01 am
Car Model*: 65 Dart, 225, 4 spd od, hyd clutch, BBD, 2 1/4 exh
Anyone tried painting and installing a dash pad overlay like this:?
https://www.ebay.com/itm/64-65-66-Dodge ... 6084!US!-1
1965 Dart 110k, 225, Carter BBD Super Six, 2 1/4 single exh., sbp manual scarebird front disc, 7 1/4 rear 2.94 sure grip, 14 x 4.5 OEM wheels, 833 OD with hyd. throwout bearing, HEI, electric fan, ram air/heated air, Accusump. http://plymouthcarclub.com/
