It is currently Fri Jul 19, 2019 5:28 am
 Post subject: My “New” engine
PostPosted: Thu Sep 13, 2018 8:51 am
Car Model*: 72 valiant
Hello,
I have been looking for a spare slant six engine to build into a blower motor.. Was preferring a running slant, but got a call from a man that pulled a slant from his moms wrecked Volare.(says 80k or so) Then he thought it was a dart. The price was free. So i grabbed it up.
At any rate the motor has the small plugs with no tubes. Im guessing its around a 1977 ? It has a factory A/C compressor, and a different carburetor than the Holley 1920 on my driver.But otherwise engine is complete less airfilter assy.
Would i be correct in thinking this does not have a forged crankshaft, but solid lifters?
Need to degrease/ clean engine to properly i.d. engine.
Is this a candidate for a blower motor build, or should i continue looking for a more appropriate year?
Thoughts, suggestions?
Thanks Russ
 Post subject: Re: My “New” engine
PostPosted: Thu Sep 13, 2018 10:22 am
Car Model*: 1965 Plymouth Belvedere I
There are some articles in the site index that will help you identify cast vs forged crank engines. Personally, I like the cast engines as they are generally lighter. I don't believe you would have problems supercharging a cast crank engine. It is high RPM/nitrous applications that you might be better served with the forged internals.
Others will likely chip in. I would defer to those with experience boosting slants.
-Matt
http://www.MattmansMopars.com
Strive for Excellence, not Perfection.
