It is currently Mon Jul 22, 2019 2:55 am
 Post subject: Overdrive.
PostPosted: Tue May 07, 2019 3:00 pm
Car Model*: 65 Valiant 2Dr Post
If you are just looking for freeway friendly driving, just forget all the expensive stuff and buy a complete parts truck or all the parts to do a factory 833 overdrive that came in thousands of trucks. Then at least all the parts are a bolt in for you. Probably less than $1000 if you are patient.
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
 Post subject: Re: Overdrive.
PostPosted: Tue May 07, 2019 3:02 pm
Car Model*:
Or buy a feather duster or a volare/ aspen parts car and do the same thing!
Greg Ondayko
69 Dart http://www.youtube.com/hyperpack
PostPosted: Sun Jul 07, 2019 12:34 pm
Car Model*:
Are you talking putting the long 833OD into the A body, or just swapping into the truck?
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Sun Jul 07, 2019 3:22 pm
Car Model*:
The truck a833 od will fit b and e bodies for those that don't know.
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Sun Jul 07, 2019 4:03 pm
Car Model*:
Are the gear ratios the same?
66 Valiant Signet 225 nitrous
PostPosted: Sun Jul 07, 2019 4:15 pm
Car Model*:
PostPosted: Sun Jul 07, 2019 8:46 pm
Car Model*:
As far as I know, all a833 od's have the same ratios.
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Sun Jul 07, 2019 10:13 pm
Car Model*: 66 Valiant, 82 D150, 94 Ram 2500 TCD
Per a really good article from Allpar, this is correct with an insignificant correction. The first three gears are the same in all OD trannys (3.09, 1.67, 1.00). Pre-74 versions have a 0.73 OD, 75 and newer are 0.71. Not enough of a difference to amount to anything.
PostPosted: Mon Jul 08, 2019 4:38 am
Car Model*:
OK, Thanks. I have a 833 OD in my truck that is very noisy, and could use syncros. I have a couple of 833 OD's of unknown condition, from unknown vehicles, on the shelf. So I have a chance of mixing/matching some parts.
PostPosted: Mon Jul 08, 2019 6:20 am
Car Model*:
There are no A-833OD units before the 1975 Model year...up to that point you are stuck with a 3 speed, the NP, and the Truck A-822 (uncle cousin brother to the 833 non-OD box).
OD boxes were advertised as .73 for car, and .71 for trucks... the change is in the pitch and tooth count of the gearsets... so if swapping guts (i.e. counter shaft and mainshaft gears),
make sure to count the teeth, or you will be in for a fun surprise when you go to assemble it.
Good Luck.
PostPosted: Mon Jul 08, 2019 7:38 am
Car Model*:
Thank you
