Click here to help support the Slant Six Forum upgrade!
It is currently Tue Jan 28, 2020 11:20 am
PostPosted: Fri Jun 14, 2019 6:27 am
Car Model*: 1963 Dart 270, 1980 D150
This swap is in a 1963 Dart. Do I need to pick up a different rear trans mount than the one for the '63 push button trans?
Thanks guys.
PostPosted: Fri Jun 14, 2019 6:31 am
Car Model*:
If the mount is still in your stock X-member, I am pretty sure you do not need to change anything. The mount only changes for the different year car's X-member, the A-body 904s (maybe all?) have the mount in the same place throughout the years.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Fri Jun 14, 2019 6:38 am
Car Model*:
If you are not using a 68 up engine/crank, this swap will not work, without a special converter.
But the mount is the same.
66 Valiant Signet 225 nitrous
PostPosted: Fri Jun 14, 2019 7:02 am
I am swapping engines as well. Thanks.
PostPosted: Fri Jun 14, 2019 10:08 am
Car Model*: '23 T-bucket
Isn't there a problem when going from a cable shifter to a linkage trans?
Roger
PostPosted: Fri Jun 14, 2019 10:58 am
I am using an aftermarket shifter.
PostPosted: Fri Jun 14, 2019 4:09 pm
Car Model*:
Then everything should be a "bolt in", except for driveshaft. There are some driveshafts that will swap right in, but i'm not sure which year/model can be used. Also rear end used will affect which driveshaft is required.
PS: speedo cable will need to be changed to one for a 66 "A" body.
PostPosted: Fri Jun 14, 2019 7:51 pm
I will have to have a driveshaft fabbed up or at least modified since I am using a 9" Ford rear end.
