It is currently Mon Jul 22, 2019 2:43 am
 Post subject: Distributor Grease
PostPosted: Thu Jun 27, 2019 10:44 pm
Car Model*:
What type of grease/oil should I use on my dizzy?
I have a 62 Valiant with a Bosch dizzy which has been completely dismantled and cleaned.
Thanks
 Post subject: Re: Distributor Grease
PostPosted: Fri Jun 28, 2019 7:45 pm
Car Model*:
for the shaft, I use a quality synthetic grease like Mobil 1 Red, although engine oil would also suffice
for the pins that the centrifical advance weights run on, I use a thin coating of dry film moly, as found at
http://kanolabs.com/indLub.html
that way you don't have a wet lube that will hold debris or run off
