It is currently Mon Nov 23, 2020 7:26 pm
Post new topic  Reply to topic  [ 141 posts ]  Go to page Previous 16 7 8 9 10
 Post subject: Re: Back in black II!
PostPosted: Thu Jul 11, 2019 11:46 pm
Moving the trans rearward may require trans tunnel mods. I had to hammer mine a little to fit. Also look at the firewall area, it is tight there on the trucks.
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Fri Jul 12, 2019 9:17 am
I have no trans tunnel on the truck, just wide open space. I am thinking Lou's suggestion of slightly moving the engine forward and the trans backward is a good one. That would mean each moved less than an inch which would require fewer modifications. However, I know I am going to have to put the truck up on jackstands, pull the 727, and spend some time measuring and thinking about things before I install. I need to have a new driveshaft made, anyway.
PostPosted: Sun Aug 18, 2019 12:50 pm
I took advantage of my brother visiting today and swapped the bed. After having a stepside bed sitting in my yard for four or five years, I FINALLY installed it:
Still have to finish up little details like fixing a ripped out taillight mounting bolt, getting all the crossmembers installed. Getting the rear of the bed mounted to the frame, etc... but the heavy lifting is done.
PostPosted: Sun Aug 18, 2019 1:41 pm
Iiiiiii like it!
PostPosted: Sun Aug 18, 2019 1:55 pm
Yep, slowly getting better.
PostPosted: Sun Aug 18, 2019 5:13 pm
swapped the bed
L :D :D KS G :D :D D
