It is currently Mon Nov 23, 2020 2:05 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
 Post subject: Re: and739's 1975 D100
PostPosted: Sun Dec 30, 2018 7:30 pm
Nice job on that intake and exhaust system!
PostPosted: Sat Feb 09, 2019 8:32 pm
Car Model: 1975 Dodge D100
Thanks for the feedback fellas! It's been a while so I thought I'd get caught up...
I the span of a week my heater blower switch and headlight switch quit working. I was afraid the two may be related to a bigger electrical problem, but turns out it was just a coincidence.
The headlight switch was crusty-dusty and corroded. RockAuto had both of these (used the discount code, thanks) and they were "pretty easy" to replace.
More recently, I dove into adjusting the valve lash for the first time in a long while. I've always used the instruction on the Engine FAQ by SSD as a guide and made up these gauge assemblies to make keeping up with the three different sizes easier.
Upon completion of the lash adjustment, I installed some chrome goodies that the the kids got me for Christmas!
I also added my custom stiletto knife oil dipstick that I fabbed up a while back. I think it goes well with the shiny stuff. :lol:
1975 Dodge D100 225 c.i., HEI, Parallel 2 bbl Motorcraft 2150, 727 auto, 9.25" 3.55:1
PostPosted: Wed Feb 13, 2019 5:11 pm
Nice.. Wouldn't want to check the Oil in a a dark alley without a flashlight... Ouch.
:D :D
p.s. What did your buddy weld the steel to cast Iron?
I might be interested in trying that sometime if I have the equipment to do so...
Greg Ondayko
PostPosted: Wed Feb 13, 2019 8:41 pm
:D :D
Haha! Thanks Greg. I’ll at least use a Harbor Freight FWP headlamp when checking oil in the dark. I cant help but say “schhhwing!” when I draw out the dipstick with that handle the way it is! :lol:
On the welding, when asked he described the process just as Doc does in the exhaust manifold modification article; heat the work, high nickel content welding rod, slow cool down. Hearing that I knew it had a good chance to turn out okay. I dropped it off late one day after work, it was welded up the next morning and I got it that day on my way home. It was still cooling off at that point.
PostPosted: Thu Feb 14, 2019 3:37 am
Online
That intake is just about the same as one I did back in the '70's. However I attached my plate using a "spray welding" technique.
Used equipement similar to this.
https://www.ebay.com/i/202524392985?rt= ... 2524392985
66 Valiant Signet 225 nitrous
PostPosted: Tue May 14, 2019 7:50 pm
We recently got new F150s at work. Last week we had aftermarket bumper/grille guards installed. From one of the takeoffs I harvested the plastic lower valance/air dam. With a little modification I think it will fit the Dodge pretty good.
What do you think?
PostPosted: Wed May 15, 2019 3:43 am
nooice..
I think Lou has done that on every car/ Van he owns. Unrolling the top 6" or so of a plastic trash can yields the same effect.
I might do one of those treatments in the future on the Grüne Hölle Project.
Greg Ondayko
PostPosted: Mon Apr 27, 2020 7:24 pm
Wow! Time flies.
Pics of the split manifold that I've been working on.
Recently I got my hands on another old manifold. It had the flapper seized up so I harvested the front three legs and the outlet.
I had a rear half section that I cut a while back. I also cut off the choke thermostat pocket since I don't use it.
Having a spare engine for mockup while working on gap clearance sure is handy!
PostPosted: Tue Apr 28, 2020 7:45 am
Nice.
Get ' er welded up.
I guess you have the correct oven / consumables for welding Cast Iron?
Greg Ondayko
PostPosted: Tue Apr 28, 2020 7:54 am
No, I won’t be doing the welding. Once everything is fitted up and Ready to go I’ll take it to a friend who’s the foreman at a local shop, he’ll weld it up good using the correct materials and process.
He’s the one that welded up my parallel two barrel intake.
PostPosted: Fri May 22, 2020 12:21 pm
I've about got my exhaust manifold pieces ready for the welding shop. The thing that gave me the most grief was matching the outlet contour to the shape of the manifold. I think it's close enough.
The 3/16" x 3" strap just had to be cut to the proper width after cleaning it up with a wire brush. I got the ends to be capped off good and flat for these.
