Slant Six Forum https://slantsix.org/forum/ |
Changed rubber hose to front passanger break, need help. https://slantsix.org/forum/viewtopic.php?t=37077 |
Author: | mikk0090 [ Sat Sep 12, 2009 7:07 am ] |
Post subject: | Changed rubber hose to front passanger break, need help. |
Hello, i just bought a d100 with a six in a row, and the front passanger rubber break hose was cracked so it failed inspection. I just replaced the hose, but now the pedal will hit the floor with poor stopping power, if i pump the breaks a couple times, then ill stop ok.. do i need to bleed the front break, if so how do i do this? any other suggestions? the year of the truck is 84, if that helps with front disc. thankyou |
Author: | Jester [ Sun Sep 13, 2009 1:09 am ] |
Post subject: | |
ahhh! you need to stop driving it and bleed all 4 brakes properly. http://www.popularmechanics.com/automot ... 13448.html |
Author: | jason white [ Sun Sep 13, 2009 3:21 am ] |
Post subject: | |
ditto what jester said |
Author: | KBB_of_TMC [ Mon Sep 14, 2009 3:11 pm ] |
Post subject: | |
If you bleed the brakes correctly and the pedal still isn't firm, don't overlook the possibility that the MC has failed. I've seen that happen often when a MC travels much more than it has in many years. I presume any of the seals travel through a (corroded?) region they haven't seen for a long time and it damages the seals. For that reason, I usually just replace or rebuild everything in the system (with the possibility of the hard lines) if there's any question at all about its condition. I find it saves time, money, and effort in the long run to just do it all at once and I've never regretted it. Beware of Chinese-made copper washers that don't seal well because they're too thin. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
