Slant Six Forum https://slantsix.org/forum/ |
How do determine wheel size https://slantsix.org/forum/viewtopic.php?f=13&t=37134 |
Author: | tgr23 [ Wed Sep 16, 2009 8:23 pm ] |
Post subject: | How do determine wheel size |
How do I determine my wheel size? This is for a 69, 4 door Valiant. Right now there are 195/75 14 tires on the car. http://www.travisruse.com/wheel/image/page1.html Thanks for the help. Travis |
Author: | CudaViking [ Wed Sep 16, 2009 9:00 pm ] |
Post subject: | |
http://www.discounttire.com/dtcs/infoBoltPatterns.dos http://www.discounttire.com/dtcs/infoSidewall.dos I hope either of these helps |
Author: | SlantSixDan [ Thu Sep 17, 2009 3:47 am ] |
Post subject: | |
He wants someone to look at the photo of his wheel and tell him if it's the 14" x 4½" or a 14" x 5½" item. I'm out of practise and so can't give a reliable answer. |
Author: | emsvitil [ Thu Sep 17, 2009 4:03 am ] |
Post subject: | |
Unless it's marked on the wheel, you need to measure it.............. Then subtract 1" from what you measure to get the inside measurement. |
Author: | SlantSixDan [ Thu Sep 17, 2009 10:29 am ] |
Post subject: | |
You don't need to measure it. The difference is visually obvious in the depth of the wheel rim visible outboard of the wheel web, it's just I'm out of practise and can't trust my memory as to what is shown in his picture. (or if the tire's removed the wheel size is stamped on the outer circumference of the barrel). |
Author: | emsvitil [ Thu Sep 17, 2009 3:02 pm ] |
Post subject: | |
SlantSixDan wrote: You don't need to measure it. The difference is visually obvious in the depth of the wheel rim visible outboard of the wheel web, it's just I'm out of practise and can't trust my memory as to what is shown in his picture. (or if the tire's removed the wheel size is stamped on the outer circumference of the barrel).
Ok............ this is a 14" x 5.5" you can compare to yours........ |
Author: | SlantSixDan [ Thu Sep 17, 2009 6:40 pm ] |
Post subject: | |
Ed: Perfect! Travis: Looks like you have 14" x 5½" wheels. |
Author: | tgr23 [ Thu Sep 17, 2009 8:07 pm ] |
Post subject: | |
Awesome! Ed thanks for posting the photo. I really appreciate the help everyone. Travis |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
