It is currently Fri Jan 22, 2021 11:10 pm
 Post subject: spindles
PostPosted: Wed Nov 06, 2019 4:09 am
Does anyone have pictures of the spindles for 9 inch brakes, and 10 in brakes, for "A" bodies? I have 9 inch brakes on my 64 Valiant, and am planing on upgrading to 10 inchers. I have several spindles that look different then the 9's, but don't know what they are from. They are very different then the 9's, but are on a 66 or older "K" member. The game plan is to do a complete "bench" rebuild of this "K" member (steering, suspension, and brakes), then swap it out, as the car
needs some suspension work, also. This way I can keep cruising while I work on it. Thanks.
66 Valiant Signet 225 nitrous
 Post subject: Re: spindles
PostPosted: Thu Nov 07, 2019 8:06 pm
IIRC, the 10" spindle takes a bigger bolt than a 9".
PostPosted: Fri Nov 08, 2019 2:54 am
Yes, bigger bolts that hold the BJs and bigger hole for the UBJ pin/shaft.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Fri Nov 08, 2019 3:10 am
The spindles I have look totally different in the steering knuckle area.
PostPosted: Fri Nov 08, 2019 9:29 am
The black one is my 10 inch on the car.
The crusty ones are 9 inch.
PostPosted: Fri Nov 08, 2019 2:16 pm
Notice how the upper ball joint stud hole is twisted around 90 deg compared to the 10 inch one.
Brian
63 Plymouth Valiant Wagon
PostPosted: Fri Nov 08, 2019 3:40 pm
Brian
Yep, that was my concern. Wanted to make sure the ones on the "K" member were correct, before starting to order parts.
Thanks
PS: You going to the Florida Mopar show this weekend? I'll be there with my 66 Valiant.
PostPosted: Fri Nov 08, 2019 5:42 pm
No not this year my rheumatoid arthritis is going to keep me away too much walking. I use to go to that show and the turkey rod run every year.
Brian
cron
