It is currently Sat Jan 23, 2021 12:33 am
PostPosted: Wed May 20, 2020 4:57 pm
Is there a source for these?
I need a 1" longer stud.
tia
--Walt Jackson
PostPosted: Thu May 21, 2020 8:54 am
Found them:
Hemi Performance, the Australian company, has them.
http://www.hemiperformance.com.au
They are described as "overlength 7 16 wheel studs".
--Walt Jackson
PostPosted: Thu May 21, 2020 4:44 pm
If you have the length and thread pitch, you can also get from summit...or if you have a local "real" autoparts store with
the orange Dorman bins, a quick search through Dorman's catalog may find a bin with what you need.
That being said, you may need a stud cutter/swedge if you are removing the original studs out of an axle or disc....
Also they may not carry the reverse hand thread Pre-1968 studs and if so you will need studs for the drivers side of the
car for the rear axle and a dozen normal lugnuts...if your car is of that era and so equipped.
