Slant Six Forum https://slantsix.org/forum/ |
Source for Longer Wheel Studs for Kelsey-Hayes Disc Brakes https://slantsix.org/forum/viewtopic.php?f=13&t=64911 |
Author: | Walter Lee Jackson [ Wed May 20, 2020 4:57 pm ] |
Post subject: | Source for Longer Wheel Studs for Kelsey-Hayes Disc Brakes |
Is there a source for these? I need a 1" longer stud. tia --Walt Jackson |
Author: | Walter Lee Jackson [ Thu May 21, 2020 8:54 am ] |
Post subject: | Re: Source for Longer Wheel Studs for Kelsey-Hayes Disc Brakes |
Found them: Hemi Performance, the Australian company, has them. http://www.hemiperformance.com.au They are described as "overlength 7 16 wheel studs". --Walt Jackson |
Author: | DusterIdiot [ Thu May 21, 2020 4:44 pm ] |
If you have the length and thread pitch, you can also get from summit...or if you have a local "real" autoparts store with the orange Dorman bins, a quick search through Dorman's catalog may find a bin with what you need. That being said, you may need a stud cutter/swedge if you are removing the original studs out of an axle or disc.... Also they may not carry the reverse hand thread Pre-1968 studs and if so you will need studs for the drivers side of the car for the rear axle and a dozen normal lugnuts...if your car is of that era and so equipped. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
