It is currently Fri Apr 19, 2024 3:18 pm
 Post subject: Brake dust shield
PostPosted: Sat Jan 09, 2021 4:49 am
So I’ve read the debates to run or not
Car is 90% drag 10% street
I had planned to run the shields cleaned up one spindle degreased wire brushed painted ready for new ball joints and hubs and reassembled
Spindle #2
The brake dust shield is rusted a lot worse behind rotor so it’s no good looked around not seeing new shields listed for 1973 A Body
Skinny drag lite front tires rotor hangs out in the air
Forget the shield or order parts hoping they fit ??
1963 Plymouth Valiant Wagon
 Post subject: Re: Brake dust shield
PostPosted: Sat Jan 09, 2021 5:58 am
I don't think it really matters much. I left them off a drag car (small weight reduction). New/used shields shouldn't be that difficult to find.
PostPosted: Sat Jan 09, 2021 9:31 am
Shield are not rally needed unless you drive in wet or dust a lot. Race cars do not use them at all to keep the brakes cooler
PostPosted: Mon Jan 11, 2021 9:03 pm
Thanks I did find them 40$
I’m going commando not going to run any should shave .01 off my ET lol thanks
PostPosted: Mon Jan 11, 2021 9:45 pm
Deep water is all they're good for. And disc brakes shed water really well.
