Slant Six Forum https://slantsix.org/forum/ |
Wilwood brakes - anti-squeal goop? https://slantsix.org/forum/viewtopic.php?f=13&t=66274 |
Author: | Badvert65 [ Wed Nov 03, 2021 1:27 pm ] |
Post subject: | Wilwood brakes - anti-squeal goop? |
OK, this is my first ever set of Wilwood brakes. I have the 120-6815 calipers w/Wilwood pads. I generally use the various anti-squeal compounds on the back of factory brakes when I service them. Is this practice recommended with Wilwood calipers? I don't want to gum up the pistons given that there aren't dust boots around the pistons. The car is still up on jack stands (for a while longer) so I can't drive and test. Just looking for recommendations and best practices. |
Author: | Greg Ondayko [ Thu Nov 04, 2021 8:18 am ] |
Post subject: | Re: Wilwood brakes - anti-squeal goop? |
I have wilwoods on Ruster - Just slap ' em on They will be fine. I Doubt the Hi End Brakes, rotors and pad compounds squeal much unless they are a super specific Road race Compound. That's my experience, I am sure others will chime in with their first hand knowledge. Greg |
Author: | Badvert65 [ Thu Nov 04, 2021 8:40 am ] |
OK, thanks. The pads I got are the BP-20 compound. They seem to be semi-metallic. If they make noise, I'll just try the BP-10 pads. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
