It is currently Sun May 05, 2024 9:30 am
PostPosted: Mon Jan 22, 2024 10:26 am
I am having problems remembering how to properly size a rear wheel cylinder for more or less lockup. The car it will be going on is a 1965 valiant 2dr with 10X2 rear drum, BUT it is not chrysler rear drums and there is a huge available list of diameters for this setup. My choices are 11/16, 3/4, 13/16, 7/8, and 15/16. If it helps the front are 10.87 disc with "pin" type mopar calipers.
The WC that are currently on the baking plates are a 7/8 but I haven't peeled the seals back to see if they can be rebuilt.
Due to stupid cost of the correct width 8.75 axles and the scarcity of BBP 8.25 I sourced a toyota truck axle. It is 55" wide at the wheel flange, comes with 10x2 drums, and a 3.91 gearset for $200.
PostPosted: Mon Jan 22, 2024 12:40 pm
13/16" was always my go-to for 10" rear drum cylinders. The 15/16" factory-installed ones are too damn big, and Chrysler knew it; see here. Could probably run the 7/8" (=14/16", between the other two sizes I mention here) with 10" front drums rather than discs, but I'd still prefer the 13/16" in back unless I routinely carried or hauled heavy weight…and then I'd want discs up front, so I'd be back to wanting 13/16" cylinders in back!
PostPosted: Mon Jan 22, 2024 5:11 pm
Online
Thanks for that linked info Dan.
PostPosted: Mon Jan 22, 2024 7:00 pm
Would 3/4" be ok for 10 x 2 1/2" rear drums and front disk (65 two door B-body)?
PostPosted: Tue Jan 23, 2024 10:22 am
I know that whatever they put into a 78 2 door b body from the factory with 10" brakes is awful touchy....
PostPosted: Tue Jan 23, 2024 10:36 am
I'd call 3/4" (12/16") rear cylinders undersized. Remember, those cop cars that originally got the 13/16" cylinders as a fix were B-bodies. I don't mean to sound like an evangelist about it, but every time I replaced 15/16" rear cylinders with 13/16" ones, the result was really, really good.
PostPosted: Tue Jan 23, 2024 1:22 pm
Online
Wish I had known this when I had my '78 Apsen
I chaed my tail with everything on that car rebuilt master cyl. prop valve etc etc. replaced shocks, tires, etc. Always touchy rear lockup!
If I could have spent $26 dollars on some undersized rear cylinders that would have been cool!
Now I know.
Awesome.
PostPosted: Tue Jan 23, 2024 4:06 pm
Car Model: 1982 D150 225, 2bbl., 833 OD
Long ago, my dad could have used Dan's fix. He had an ordered 1978 Chrysler Lebaron. Same problem with easy lock up of rear drums. I guess that the Lebaron was essentially a post '67 A body.
Despite multiple dealer and other visits, it never was much improved in the 10 years that he owned it. Years later, I read of one other fix which involved fitting a Ford portioning/ metering valve without quite so much initial rear brake bias.Swapping out rear brake cylinders would be cheaper and easier.
1982 Dodge D150 ( Ram)
225 with A833OD. 2bbl. Non power brakes
PostPosted: Thu Jan 25, 2024 10:44 am
Back in the 90s mopar action covered the rear wheel cylinder sizing. I couldn't remember which sizes worked best and couldn't find any easy search results for the topic. So I started this thread knowing that someone here would know a good answer. Now when someone searches they have this resource. Thanks for the answers.
PostPosted: Thu Jan 25, 2024 12:01 pm
No, the '78 LeBaron was a C-body, much bigger than an A-body.
…with that publication/author's usual delicious blend of truthy-flavored nonsense, made-up wishguesses, baseless claims, and a percentage of whole-grain facts. Part of this complete breakfast; stays crispy and crunchy in milk, yum-yum!
PostPosted: Thu Jan 25, 2024 2:20 pm
Wrong again.
The 78 LeBron was actually one of the first of the M bodies
PostPosted: Thu Jan 25, 2024 5:26 pm
volaredon wrote:
Wrong again
Oh! Whatchya mean 'again', what was I wrong about before in this thread? Is this like that preaching thing you were on about the other day?
Derp, right—I was thinking of the Noo Yawkuh. :mrgreen:
